Gon fix it with me hammer
svandamme's Avatar
mfi rod length?
Can anyone tell me what the exact dimensions are for the mfi control rods?
i'm having some made , but can't measure, because my old rods are in the garage ( 70km from my house ) and they are broken and bent
would need the length of the rods and also the lenght of the threads on each end?
and if anybody knows the length of the other 3
1 x rack to pump
2 x rack to throttle valves
would have a full set made while they're at it
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-22-2005, 03:05 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Just measured mine....
Bore to bore....about 118 mm
From cross bar to center bore about 140 mm
From cross bar to main throttle pivot (to pedal) about 290 mm.
and the cross bar to pump is supposed to be 114 mm.
Hope this helps.
Bob
Bob Hutson
Old 08-22-2005, 07:30 AM
svandamme's Avatar
bore to bore, you mean the rod itself, including the threaded part
minus the ball joints , right?
the cross bar to pum is 114 , yes ,but that's including the ball joints
i need the measurements ,without the ball joints..
i can't measure mine , since the reason for needing new ones
is that i broke one of mine , in an attempt to disassemble them ( and correctly adjust them )
the ball joints are corroded stuck on the rods themselfs
so i can't measure
Stijn Vandamme
Old 08-22-2005, 07:46 AM
ttweed's Avatar
It's probably too late for your project, and shipping might be a hassle to Rotterdam, but Supertec is reproducing the short linkage rods now in sets of four for $80. http://www.supertecperformance.com/new-porsche-products.phtml
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
svandamme's Avatar
i know , but normal shipping takes forever
and express shipping effectivly doubles the price
Stijn Vandamme
Old 08-22-2005, 08:00 AM
