Adding a wire for a tail light problem
I can not figure out my left rear tail light (not blinker or stop) just a light that goes on when driving at night. Can anyone think of a way for me to run the wire without drilling a hole next to where the left tail light harness goes through the body. I am all set the rest of the way.
Any ideas? Thanks, David |
David,
There should already be a spare wire in the harness to the left rear lamp housing for the 'Euro' rear fog lamp. On early cars it is a White/Green wire behind the dash and folded/taped up ... where the fog lamp switch should go. At the lamp assembly the color changes to Green/White. |
Thanks Warren.
Say I can't find itm any other ideas? I have a wire running from the from fuse box to the engine compartment, I just need to get it out to the light in the tail light assembly. David |
Can you access any other wires to the assembly? If so. tie or tape another wire or string to it/them, pull it all back to the engine compartment, leaving the pull string exposed out the back. Then tie the new wire on and pull it all back to the light.
| All times are GMT -8. The time now is 05:27 AM. |
