Please tell me all I ned to know about using steel lug nuts on a 911
I'm thinking about replacing my worn out alloy lug nuts with steel ones. My questions are:
1. What is the difference between the unplated lug nuts and the (apparently unplated) black ones? Which ones are OEM? Which ones stay the nicest looking the longest? 2. Do you still use never seize on the threaqds with the steel lug nuts? 3. Do you use never sieze on the radiused area on the nut where it touches the wheel? Thanks Jim |
Steel lugs are stronger than alloy ones. I would only use steel lugs on the track. I also use the steel open lug nut version.
I put anti-seize on the threads, not on the mating surface of the nut to the wheel. The torque is higher for the steelies, too. I torque to 95 ft/lbs. Don't know which ones last longer as far as looks...
I use a little on the threads and on the radius surface.
-Chris |
they weigh too much
most track people use them, less than $2 ea, used one are ok too......
Mike,
FYI ... there is no difference in the torque spec for steel or alloy lug nuts!!! Per the factory service manual ... 94 lb-ft for both. |
There are two steel lug nuts.
IMAGE LugNutSteel01.jpg http://forums.pelicanparts.com/uploa...1122154054.jpg There is the early one (on right) used on 356 and 911/912 up through ’67. The outer diameter measures 24 mm but everything else is the same. The later one (on left) began in ’68 and is a current part. The OD measures 26 mm and is a nicely manufactured forged part. It is slightly shorter. The later one fits the Fuchs and all others properly. There are some current BBS wheels where the 26 mm nuts won’t clear the recess hole. Note that the contact surface has a spherical profile. These are not tapered. Part of regular maintenance is removing the lug nuts for cleaning and inspection. I put slight lube on both the threads and contact surface – mostly for corrosion protection. There is a VW part used on 914s that fits over the 19 mm wrench surface. It is about as tall as an alloy lug nut and just pushed on over the nut. They are plastic and serve to keep water and road grime off the nut and threads. They will clear about 12 mm of additional stud protruding from a steel nut. Here is a slightly shorter version that clears 9 threads protruding. It has an external hex of about 22 mm. If some thief tries to remove the wheel without removing these caps; all that will happen is the plastic cap gets trashed – the lug nut won’t budge. IMAGE LugNutPlasticCap01.jpg http://forums.pelicanparts.com/uploa...1122154145.jpg The reason most track organizations want an open end lug nut is so the tech inspector can see that there is full penetration of the stud through the nut. A few turns of engagement isn’t sufficient. MIL spec is 1 ½ threads through the nut and I suspect ISO is the same. For lightweight track use you can turn off the closed end of the alloy lug nuts. Best, Grady |
getting some for my track cars, good info, Grady thx
Thanks for the replies, everybody had good input. I posted this the night before the family and I left on an all day rafting trip down the Ocoee River in TN (Class III and IV+, including the Olympic section). I came back and found more information than I would have expected!
BTW, we all stayed in the raft! Thanks again, everyone. Jim |
Where would one buy these steel lug nuts, say for my 81 SC?
George |
Pelican sells steel lug nuts. It's common for people to use the VW Transporter pieces, because they are cheap, steel, and have the spherical mating surface.
When Eric McKenna Gets online he can tell you. Something about losing his wheels on the track.
does pelican sell the open or closed steel lug nuts?
Open.
Joe A |
| All times are GMT -8. The time now is 03:35 AM. |
