Front bumper cut
I'm installing a Setrab front oil cooler but don't want to modify the tub to keep the car within PCA racing rules. I need to notch the front bumper bottom lip about 2 inches. The question is: can I do that with a jig saw or I need some special tool (torch - don't want because of heat and paint don't match) to make the cut. Need advise...
Old 04-08-2005, 05:38 AM
Designer King
Paulporsche's Avatar
I think a jigsaw would do it. Just remember to use a suitable blade (the bumper is aluminum) and tape the bumper itself or the bottom of the saw to avoid scratches.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-08-2005, 08:33 AM
Thank you Paul, I didn't know the bumper is made out of aluminun, I assumed it was made out of steel (being a bumper = very strong = steel) wrong!!!
Old 04-08-2005, 09:13 AM
Me like track days
Craig 930 RS's Avatar
I've done this exact op - its pretty easy.
I also used a hole saw to zap about 7 holes on the face of the bumper -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-08-2005, 09:19 AM
Designer King
Miguel,
I am assuming you have an S, SC or Carrera w/ impact bumpers.
Paul
Old 04-08-2005, 09:27 AM
Paul, it is a 78 930 and I am tying to maintain the original front valance with a minor modification to install the cooler; you know, one of those "engineering" projects... I personally don't like those aftermarket valances that go all the way to the front of the bumper. We'll see. When I'm done I'll post pictures of it.
Old 04-08-2005, 09:48 AM
ecm911's Avatar
Miguel,
How did you make out cutting the bumper. I am about to do the same thing. I also want to keep it PCA legal.
Would be interesting in any advice.
Thanks,
Earl
78 SC Coupe
93 RSA (Gone)
Old 07-24-2005, 01:08 PM
