Mark Wilson
Guest
Posts: n/a
Early Flag Mirror Motor Replacement Pics
There are several threads that explain the process, but I didn't find step by step photos. Very simple to do. Tools needed were a wide putty knife with a rag wraped around. a flat screwdriver and a nutdriver (I used 5/16). This was done on a 79.
Use the wrapped putty knife to pry mirror off backing plate. Heating grid is on back of glass so watch where you pry. There are 3 posts on the back of the mirror that friction fit into grommets on the backing plate.
Disconnect the 2 wires to the heat grid. Note orientation.
There are 3 screws holding the motor assembly to the mirror housing. Take these out next.
continued-
Old 07-23-2005, 06:22 PM
Mark Wilson
Guest
Posts: n/a
This is the electical connector. Use a wide flat screwdriver to separate the connector.
Reinstall the new motor assembly in the reverse order.
pwd72s's Avatar
Mark, wait until this post hits page 2 to four...then another post will show: "Pics wanted..." Good job!
Old 07-23-2005, 07:17 PM
Mark Wilson
Guest
Posts: n/a
Thanks Paul!
Old 07-23-2005, 07:44 PM
