-   -   Lost 3rd and 4th gears ('89 930) (http://forums.pelicanparts.com/porsche-911-technical-forum/232705-lost-3rd-4th-gears-89-930-a.html)
db_in_qld 07-24-2005 06:03 PM
"Lost" 3rd and 4th gears ('86 930)
Hi, wondering if anyone can help? While driving over the weekend I "lost" (the ability to shift into) 3rd and 4th gears. It feels as though the linkage is loose or disconnected, as when I try to select 3rd, it slots 1st and similarly 4th is slotting 2nd...
Is the problem in the shift assembly (gear stick), or is it where the shaft meets the gear-box selector under the rear seats???
I'm hoping this is a quick, easy and cheap repair/fix i.e. tighten up a bolt... Thanks in advance!
db_in_qld 07-24-2005 07:30 PM
I thought this would be an easy-fix..? Can anyone help??
island911 07-24-2005 08:13 PM
Sounds like a loose or broken shift fork. (?)
Maybe John Walker will chime in Monday. PDT
db_in_qld 07-24-2005 08:17 PM
Thanks Island. The shift fork is located under the rear seats isn't it?? It is what connects the shaft to the gear box and has a pin going through it...
Joe Bob 07-24-2005 08:23 PM
Fork be in the da trans...the shift linkage may have slipped. That's in the tunnel under the carpet behind the front seats.....
db_in_qld 07-24-2005 08:29 PM
Thanks heaps man That's kinda where I thought - just haven't looked yet. Get onto it tonight. :) :)
