aftermath's Avatar
how do you store a fuel pump?
Im pulling a car apart and I know the project will take a long time.
Since fuel lubricates the pump and maybe prevents corrosion...
Do I leave fuel in the fuel pump, or drain it?
If I leave fuel in maybe a short hose on either end with some clamps?
If I drain it, anything to spray\run through the inside to protect it prior to setting it aside?
Anything special I should be doing with fuel lines while Im at it?
Does someone know about any good threads \ reading material on how to store a vehicle?
theamsoilguy@hotmail.com
Old 07-25-2005, 01:57 PM
Ron asked this question not to long ago..... Used Fuel Pump Storage ?
Warren & Ron, may you rest in Peace.
Old 07-25-2005, 02:17 PM
jax jax is offline
If you're removing the pump from the vehicle, drain it well, attach short
hose to suction side & run a small amount of diesel fuel thru pump with battery power. 5 seconds will do it & keep it lubed.
Old 07-26-2005, 11:48 AM
Jubbie's Avatar
I pulled the fuel pump out of my 74 Targa after it set up with gas in it for 20 years. I was told to soak it in carb cleaner and then try it out. After all that time in that poor storage environment, it still works like a champ.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 07-26-2005, 11:55 AM
