-   -   I didn't think I could ever get sick of dremmeling (http://forums.pelicanparts.com/porsche-911-technical-forum/232736-i-didnt-think-i-could-ever-get-sick-dremmeling.html)
eskimo 07-24-2005 11:40 PM
I didn't think I could ever get sick of dremmeling, but I'm cutting off my cat and muffler.. Man-o-man, will I ever get this thing off..
3 hours of fiberglass cutting wheels, and I've gotten the heat shield off and 4 headless bolts.. A few more to go tomorrow.
My close friends and my wife think I'm dremmel crazy.
87coupe 07-25-2005 12:23 AM
I think you need a cutting wheel, save the dremmel for smaller tasks ;)
island911 07-25-2005 12:33 AM
See http://forums.pelicanparts.com/showthread.php?s=&threadid=144743&highlight=carbid e
slow&rusty 07-25-2005 06:17 AM
Dude...."Grinder and cut-off wheel"....why the agony of a Dremel? Don't bring a knife to a gun fight!
Yasin
PorscheG 07-25-2005 06:13 PM
I did the samething with my Dremel. After that used Stainless steel bolts
and nuts.
Now I can switch the Cat with the Premuffler in about 1 hour.
Good luck, don't give up, The Dremmel will do it. (It is not easy though)
randywebb 07-25-2005 06:13 PM
or a Roto-Zip - half way between each one...
Dantilla 07-25-2005 06:37 PM
I love my Sawzall.
tabascobobcat 07-25-2005 07:12 PM
Roto-Zips Rock
gost 07-25-2005 07:17 PM
A 3" air cut off tool, only way to fly. 10 seconds a bolt! And the light show is pretty cool.
emcon5 07-25-2005 07:24 PM
Ten Bucks.
http://www.harborfreight.com/cpi/pho...3199/03150.gif
Tom
jtratza 07-25-2005 08:40 PM
Harborfreight is unreal for bargins. I feel your pain Eskimo. I was in the garage tonight cutting the three frozen bolts off the cross over pipe. I got two off before the dremel blade broke. I found cutting with the dremel and finishing with a hack saw worked best. The all I had to do was drill out the last 16 of an inch. Took about ten minutes for each bolt but my exhaust system is off the car and on the floor which makes it very easy. The cat BP bolts were replaced years ago when the cat got taken off. I'm going to replace them again but with a stainless bolt as above and maybe a different metal for the nut.
eskimo 07-25-2005 09:25 PM
I got em ALL..
"all dremmel. all the time..."
Those big saw are nice, but I really like the ... (dare I say) "daintiness" of that little tool. With those 1.5 inch fiberglass blades you can get to some pretty tight places.
I was told to stop making so much damn noise in the garage, so now I've been relegated to the basement, for internet, trance music, booze and cigarettes.. (and she EXPECTS me to actually finish this car)
That targa should be on the road by 2007 if I keep this up.
Mike Andrew 07-26-2005 09:56 AM
Feel your pain. I dremmeled off all the same bolts when I replaced my exhaust.
Never again - FLAME ON!
Warviking 07-26-2005 12:18 PM
I used a dremmel also. But I used a bit that looks kinda like a drill bit but is used for cutting metal. Worked real good. On the cat I just cut off each side of the nuts and then chiseled them off. I have a grinder too but it didn't fit in there so good and the sparks were a bit much.
thabaer 07-26-2005 12:33 PM
You can get a pack of cut-off wheels and a mandrel for your dremel that work great on smaller stuff. When I fought my siezed cat bolts a die-grinder and cutting disc worked wonders (and fast!).
Hugh R 07-26-2005 12:47 PM
Try the Sears "Bolt Out" sockets, as seen on TV with Bob Vila, they're sockets with internal biting teeth, and they work well.
