Sunroof ajar
Just noticed that rear part of my sunroof (driver side) was not snug against roof. I replaced cables and felt a few weeks back and all has been fine since then. I am familiar w sunroof components but wanted to see anyone had similar issue before I began to tear apart.
I took the headliner cover off the sunroof and all visually appears ok. Pushing up from the inside of the car is not making it fit properly. Passanger side is snug. Motor sounds fine. Seems weird. Thanks for any tips. Chris
Chris 1985 Carrera http://www.pelicanparts.com/gallery/ckmaggie |
Mine does this sometimes but I just push the button and hold it for a few more seconds and it closes all the way. You probably tried this but I thought just maybe??
UFLYICU
There are adjustments on the sliders that the cable fits into. Look closely to see how they will adjust to push the sunroof up tightly.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
The adjusters were set fine when I reinstalled the roof. I suppose they could have come loose.
UFLYICU
If there are no plastic washers to allow movement, they will unscrew and fail to press upwards.
Information Junky
From your description, it sound more like the cables aren't aligned back at the motor/drive-gear.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Registered Cruiser
If the gap remains constant throughout the travel of the roof panel then your cables are not aligned properly. If the alignment changes just before the panel seals then it needs to be adjusted via the ratcheting height adjustment screw.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
