Patton's Avatar
Relay Positions
My 1987 930 does not have a fuse/relay cover. Can someone tell me the order of the relays. I know that the two over compartment #3 fuses are fuel pump relays. I do have the order of the fuses.
Patton
No Porsche at the moment but give me 6 months and then......
Old 07-23-2005, 10:33 AM
#1 A/C
#2 Fog Light
#3 Horn
#4 not occupied
#5 Elect. Windows
#6 Fuel Pump #1 front
#7 Fuel Pump #2 rear
Old 07-24-2005, 09:50 AM
Patton's Avatar
Thanks Greg,
I guess because the car set for an undetermined period of time, the light sockets in for the headlamps were loose (connections) and it caused a ground short. What a bummer to find but at least I'm up and good to go again.
Patton
Old 07-24-2005, 11:03 AM
I am glad you got it running ok. Can you do me a favor? There are 4 relays in luggage comp. on drivers side back by the ign. switch. I think I have two of them switched. When you get some time, can you get me the relay numbers, say from right to left. Having a problem and I think that is where its from. No hurry at all, just when you get a second. Thanks Greg
Old 07-24-2005, 11:10 AM
Patton's Avatar
From left to right:
#3- 92861811301
#2- 91161810200
#1- 898329000 (Power Window Relay)
Patton
Old 07-26-2005, 03:49 AM
Thanks Patton, I know those relays are kind of a hastle to get too, I really appreciate that, Thanks again.
Old 07-26-2005, 09:05 AM
