Need help with part#'s
I'm attempting to rebuild an engine for the first time (I love pain) and have come across some part # I cant find. The car is a 77 911 w/2.7.
What are the following as far as alusil/nikasil/year/type/etc: Cylinders- 90ZN2 W5 and 6 Case- 910 101 102 7R Engine serial #- 6551182 Pistons- 90P27 Camshaft- (R) 911 105 144 0R (L) 911 105 143 0R Camshaft tower- 901 105 11 0R Thanks |
bump
Engine serial #- 6551182 is a '75 Ca. 2.7 Carrera, 911/44, engine nothing special except it has the 7r case, and countered by the oem thermal reactors which were originally on it.
the cams are the stock cis S smog cams |
Thanks Bill
The pistons are RS pistons (two valve pockets across from each other), is that good/bad/normal? |
bump
Come on guys, Are the RS pistons good/bad?
| All times are GMT -8. The time now is 01:03 AM. |
