Relay Positions
My 1987 930 does not have a fuse/relay cover. Can someone tell me the order of the relays. I know that the two over compartment #3 fuses are fuel pump relays. I do have the order of the fuses.
Patton No Porsche at the moment but give me 6 months and then...... |
#1 A/C
#2 Fog Light #3 Horn #4 not occupied #5 Elect. Windows #6 Fuel Pump #1 front #7 Fuel Pump #2 rear |
Thanks Greg,
I guess because the car set for an undetermined period of time, the light sockets in for the headlamps were loose (connections) and it caused a ground short. What a bummer to find but at least I'm up and good to go again.
I am glad you got it running ok. Can you do me a favor? There are 4 relays in luggage comp. on drivers side back by the ign. switch. I think I have two of them switched. When you get some time, can you get me the relay numbers, say from right to left. Having a problem and I think that is where its from. No hurry at all, just when you get a second. Thanks Greg
From left to right:
#3- 92861811301 #2- 91161810200 #1- 898329000 (Power Window Relay)
Thanks Patton, I know those relays are kind of a hastle to get too, I really appreciate that, Thanks again.
