How does one go about finding out if this front koni strut is bent? I have an issue that doesnt allow less than 2 degrees of camber on the passenger side and im trying to find out what it is.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Take a look at where the spindle part is attached to the strut. If the damage was fairly recent, you will see "disturbed" dirt where the spindle collar surrounds the strut. Another way is when you can't get the sturt insert in or out of the strut housing.
Heres a really bent one that I pulled off a 993 some time back.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
