Angry Troublesome Targa Top
Before every screams enough with the targa troubles!' I have done a search and got close to finding a solution.
Has anyone actually successfully trimmed their newly purchased front and rear rubbers to make the targa fit better. Ii have the dreaded wind getting in. however it doesn't leak.
Basically i have a large gap at the back and the front passenger side is raised...thanks for any help.
Will post pics later
Old 07-26-2005, 02:59 AM
is the rear rubber set low enough ?
Old 07-27-2005, 01:42 AM
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
are the front & rear "clips" catching the folding frame properly when the top is opened/unfolded completely ???
Greg....PCA, 356 Registry, 912 Registry
1977 911S Targa with 3.2...1960 T-5 coupe
1968 912 coupe, that's 32 P-cars, so far...
1990 Chevy 4x4 2500 pickup (with 255K & still rockin')
Old 07-27-2005, 02:53 AM
yes, they catch fairly well
Old 07-27-2005, 03:27 AM
do you have a Targa Buddy with a car close to same year as yours (the top latch changed @ 1985 ???) that you can do a top swap...try yours on his & vis versa, to see how or if the problem transferes from car to car. Plus you can do a general eye balling of both cars/tops to see if anything seems different.
good luck
Old 07-27-2005, 03:41 AM
