Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
915 Transmission into 1969 911. Who's done it, what's involved?
Hi,
I'm just about to have my "get the car together on thursday" party, and Grady Clay, in his infinite wisdom, let me know that the 915 doesn't exactly "bolt-in" to the 69 chassis. So..if anyone has done it, I'd love to hear what was involved, and if there are any workarounds.
Thanks,
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-27-2005, 03:26 PM
Plavan's Avatar
There should be info on this board. Use the search funtion.
I know it requires a little banging of the tunnel with a hammer to make room.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 07-27-2005, 03:30 PM
Rennch on YouTube
rennch's Avatar
I've tried, but haven't had much luck finding the info I need. I'm always a "search before post-er".
Michael O'Neal -
Old 07-27-2005, 03:36 PM
Plavan's Avatar
915 Tranny in Early Chassis
What is needed to swap a 901 with a 915, and is it worth it?
911 / 915 gear box swap?
Good info in a few of those. I searched 915 swap.
Chad Plavan
Old 07-27-2005, 03:43 PM
Rennch on YouTube
rennch's Avatar
Thanks for finding that stuff. sometimes you just have to search exactly the right way. Well...it looks to me like it's doable with a hammer, which is my preferred weekend racer method.
whew...
Michael O'Neal -
Old 07-27-2005, 03:48 PM
Plavan's Avatar
No big deal. Hammer and beer..... I reccommend using the hammer first
Chad Plavan
Old 07-27-2005, 03:50 PM
1) get corresponding clutch cable
2) get corresponding clutch arm that goes in the pedal assy- might as well buy a new set of bushings for it while you are in there
3) get corresponding axles for the 915
4) get the shift tower and long tunnel rod for the 915 (or search the archives on how much to shorten the 69 unit)
5) with the transmission only mounted in place, raise the bell housing till you see where it interferes with the back seat area. Take Porsche tool # big A$$ hammer and pound in on both sides.
6) check back up wiring leads and modify if needed
7) check on speedo you will be using- if electronic- run a pair of thin guage wires down the center tunnel, into the front trunk, then behind the guages for hook up. you will also need a positive source of power for the speedo
8) make sure you have the correct clutch package for the trans and finally the right length mounting studs to go thru the bell housing from the motor
have fun
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 07-27-2005, 04:00 PM
Rennch on YouTube
rennch's Avatar
Nice list TRE...thanks.
Michael O'Neal -
Old 07-27-2005, 04:02 PM
A little mod to Dave's list. If you have an electronic speedo, instead of passing loose wires through the tunnel, use the existing speedo cable housing as a sheath for the signal wires (remove speedo cable first). The sheath conveniently ends right behind the gauges anyway.
You can PM me for more info if you want. I have a '69 with a 915.
Sherwood
http://members.rennlist.org/911pcars
Old 07-27-2005, 04:15 PM
nice touch sherwood- thanks for the tip
1970 911 Targa "ST"
Old 07-27-2005, 04:18 PM
Rennch on YouTube
rennch's Avatar
Thanks Sherwood. Good advice all around.
Michael O'Neal -
arrivederci's Avatar
Oh boy we're gonna had fun tomorrow.
- '72 911T
- '81 911SC Euro
Old 07-27-2005, 06:34 PM
Rennch on YouTube
rennch's Avatar
indeed we will...
Michael O'Neal -
Old 07-27-2005, 06:38 PM
Britain Smith's Avatar
Here are several pictures of me making the modification to the center tunnel on my '69.
915 Tranny Install
Here is where it hits:
Here is the spot I beat in:
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 07-27-2005, 11:42 PM
Britain Smith,
Why does it look like you have a wheel bearing attached to your gearbox mount?
Sherwood
Old 07-28-2005, 12:35 AM
Rennch on YouTube
rennch's Avatar
Britain,
Great photos...thanks. And I was going to ask the same thing. Is that for the transmission swingarm? (Not to be confused with Blinker Fluid or Muffler Bearings)
Michael O'Neal -
Old 07-28-2005, 06:18 AM
Originally posted by 911pcars
Britain Smith,
Sherwood
Well, the 915 transmission mount required a short bolt than I could locate so I figure a bearing would do the trick as a large spacer for the time being...you mean that isn't where it goes?
-Britain
Old 07-28-2005, 03:26 PM
No problem. What kind of grease do you use? I first thought this was used to tighten the turning circle or to rotate tighter into a turn.
Sherwood
Old 07-28-2005, 03:34 PM
