Sportomatic Oil Seals
While the motor's out I thought it would be a great time to replace any seals that I can easily get to on the trans. The oil seal at the torque converter has been known to leak and would cause a problem with the clutch.
Anyone know of a supplier for them? Thanks, Dave
Dave Taylor 1974 911 Coupe 2.7 Guards Red/Black Trim, Tbitz EFI, MSD 1974 Super Beetle Sun Bug 1959 356A (sold) 1954 Hudson Hornet Project For Sale 18 Years In Storage 1974 911 My Car in the Pelican Gallery |
bump...
Do you have a part number? Some of the seals are NLA but part of the reason is they can be reproduced very easily. I would call Pelican maybe.
68 911L |
Thanks....I'll get the number off of it and call Pelican.
Dave
From the 1973 parts catalog:
Torgue converter: Smaller seal on engine side: 999.113.071.50 25mm x 35mm x 6mm; superceded to PCG11307150; Pelican's online system shows they can get it for $10.59 each. Larger seal on transmission side: 999.113.189.40 45mm x 60mm x 7mm; Pelican's on-line system shows they can get it for $38.15 each. Transmission input shaft seal (in transmission bell housing): 999.113.069.50 22mm x 35mm x 8mm; superceded to 999.113.286.40; Pelican's on-line system shows they can get it for $25.62 each. |
Wow! Thanks Jim! I'll get those ordered right away.
Dave
Well, the good news is that Pelican can get the 999.113.071.50 so I ordered it today. Bad news is they can't get the big one: 999.113.189.40.
It's made by Goetze and is 45mm x 60mm x 7mm. Any Sporto people out there that can point me in the right direction? Thanks, Dave
