abit off center
cgarr's Avatar
Tube bending?
I hope someone has done some of this? I am going to try and bend up some 1 1/2 .035 wall stainless steel 304 tubing, nothing over a 45, I was looking at those cheap import tube/pipe benders with the jack and dies, do these work on thin tubing or am I going to kink it? Someone out there must have done up their own roll cages? what works best?
Thanks Craig
Old 07-28-2005, 01:44 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
We used to fill the tubes with loose sand and pack it in as tight as possible.
Then use a bender that supports the sides of the tube as you bend (the dies look like a tube cut in half).
With a little care...you can bend 90 deg or more with out too much crush.
Bob
Bob Hutson
Old 07-28-2005, 02:05 PM
sammygon1's Avatar
Check out VanSant enterprises I have their model 3 bender and it works very well. Each die has specs for the recommended wall thickness of the tube.
http://vansantent.com/model_3_bender.htm
Sam Gonzales
'69 912 2.0 -6 power
Old 07-28-2005, 02:23 PM
