To begin, I think the therapy that I will need as a result of this seemingly small project will exceed the cost of the car.
Anyone who may considering installing the oil cooler scoop may want to consider again...or not depending on if you're a masocist or not.... I started at about 1pm and was finished at about 7pm...now that did include 3 trips to a local hardware store, Kragen, and Sears. First thing I would suggest is that you have rachet extentions, a very long rachet, various small wrenches, and of course much patience. I went by the instructions posted in the Tech section of this site and it seemed very straighforward from the instructions...what it did not say was just HOW TIGHT the workspace underneath in fact was...now my hands aren't THAT large but both my hands and forearms are pretty shredded right now. Yes you most certainly need to take the horn out-- but even when it's dangling room is at a minimum. Then there is this bracket with 4 bolts that covers the inside of the light (I used both a long rachet and extensions for the socket but there was a lot of slack in this arrangements so you must really be patient)...this is a complete nightmare to get off...once you do I felt it best to remove it from the car...now this is a big heavy bracket that seemingly has no purpose other than provide extra support should a fender bender occur. Well I loosened the buttom fender and was able to pull the bracket through and remove...I chose not to reinstall it. Now I don't know if other years have this but mine is an 1988. Once that was removed you have to remove two bolts that undo the parking light. That was a picnic as one of the bolts you basically have to unscrew blindly...I had to get a little wrench up there and blindly feel around to keep unscrewing it. Putting everything together was much easier but honestly I felt like giving up more than a few times. This is not a technically challenging project but it is incredibly aggravating in that you simply cannot reach bolts with ease and your hands do not fit. I read somewhere that it may just be easier to undo the bumper but wasn't sure how many bolts are involved and where they were so I just did it the way as per the instructions. I hope others had a better time than I did. Anyway it looks ok, now I just hope it works. Cheers,
Honest honey it's not a porn site...close but not quite. 2007 BMW 335 coupe 2005 Ducati Multistrada 2001 BMW 1100SA Light |
yes, working on that side is a major pain...to get access to the nuts is really difficult. End up removing fog lights, turning wheel all the way (to come from behind the bumper).
I have the RUF front bumper on there, and installing that was also a major pain in the butt.... actually, the other side has a washer bottle and can also cause problems with the other signal. Indeed, everything is always crammed in around every space on these cars.
-kb- |
The upside to it all is that the oil scoop plain works...at least 30-40 degress cooler when I'm moving...recommend to all!
Registered Cruiser
Yo dp,
How about a pic!
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
ok ok..i feel so loved...last one is my wife and I during a VERY recent shower...I got the car as my sanity away from the soon to be twins. By the way, I also installed a Steve Wong chip and am extremely happy with it!
Sorry, guys, but that sounds like a rather minor inconvenience ...
... compared to installing a new clutch cable assembly on a 1994 Nissan Sentra! It took two weeks, with major layoffs for blood pressure to settle down, allow cuts and scratches to heal ... and plan new approach strategies to the pedal cluster with my hands, neck and head to recover the broken clevis that just pulled off the end of the old cable, and wedged itself between two pedals ... visit to chiropracter for back/neck problems ... a few days worth of Vioxx ... and my hands and forearms looked like I had stuck them in a cage with an enraged Wolverine! Besides that ... the cable was over $65 -- more than twice what one for my 911 costs!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Registered Cruiser
Congrats on the Carrera AND the twins! You can fit them both in the back. My 2 yr old loves the 911.
Doesn't want/need a 3.6L
I would speculate it may help a bit, but temp reductions you quote are like adding a front mount cooler or another Carrera cooler in the left fenderwell. Not saying you're incorrect, but more info as to how you measured these changes would be helpful. Has anyone else who's installed this "scoop" gotten similar temp reductions? Ralph |
sierra nevada! mmmmm.
congrats on the twins! i got the same bracket. i use it for a doorstop now, instead of my trailer hitch. i think removing it, leaves a big hole for the air to slide past without going thru the cooler, but i havent had any issues, and doesnt sound like you are either. warren, funny story. i had a hell job installing a over the counter tranny cooler on a friend's truck. it was hell! i left the job, once it was in to let him deal with the final hoses. he ended up pinching a rubber hose tight, with the fan shroud, and blew up his tranny. we were not proud.
poof! gone |
Horrible Story Warren...I guess I'll shut up now about my hell
Regarding the temperatures...we've been having about 100degree heat where I am (Pleasanton CA) and the car was running on the highway a little higher than the second (yellow) arrow on the image below. Now with the oil scoop the temp is where the actual orange needle is...again very happy with the result.
UFLYICU
Nice '88. The color is almost perfect.
![]() I got dibs when the priorities shift. My wife wants a cab.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Funny you mention getting the car as an "escape" - with your wife being pregnant.. Mine's pregnant too (not twins, though), and I justified the car as an "additional" car for when the baby comes...
1987 BMW 528e |
Hey man what ever works!
Doesn't anybody work around here??? Everyone just kicking back and writing posts...hhhmmm what's my excuse...
...3:30 on Friday... no way I'm working... I'm just trying to stay awake
1987 BMW 528e |
depoltizer,
Soryy you had such a hard time with the scoop but glad to see its working well for you. When I wrote the directions for the scoop i had no idea that that plate behind the lite even existed and to this day I can't find any info on what years have it and what it is. Not all 88's have it , just some. When I wrote the directions I had r&r the prototpes a hundred times so I could do it in my sleep so I had my son do it from my directions to be sure i wasn't making the installation sound to simple. Your car is very nice. Good luck with the twins Jerry JM PRODUCT DESIGN |
Your temps seem a bit high to me. I run about where your pointer now is, in Dallas during Summer. Of course, I don't have any A/C load...
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
My 930 runs about the same as dpolitzer's before the scoop when sitting in traffic. On the freeway on a warm day it stays around 9 o'clock. I'll be adding a front mounted cooler soon.
Wow...i didn't expect a post from the designer himself
Again, the product is simple but effective and maybe I just need smaller hands for the install....ok, maybe freakishly smaller hands...Yeah, I was surprised about the temps too...but with the air cond going and possible 100deg+ temp outside..i truly felt for the engine. Now I can stop looking at the needle as it now consistantly stays at about 8 o'clock (when moving of course). The nice thing is that even in traffic when the needle creeps up a bit the temp cools down much faster than before when i begin moving again.
That is it. I am getting the scoop.
Mike |
Large Registered Member
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
