turn signal, whats wrong?
Awhile ago, the left turn signal started to flash faster then the right one when activated. I thought a bulb was out, but no, I checked. Now when I activate it, I hear a buzz coming from the dash behind the guages.The signal does'nt work. Does this mean the relay is bad? What should I look for and where? Thanks
turn signal..or turn signal indicator? the turn signal relay is located there behind the fuel gauge..pull it out and you'll be able to see it..a black plastic square on mine if i recall. when i had turn signal indicator problems a couple years ago (and coincidentally this week!!), i replaced my relay and it solved the problem. i think it's about a $35 part. maybe try pulling, cleaning contacts and reseating it. if you can borrow one from a friend's car, you may be able to narrow it down. good luck.
ryan |
| All times are GMT -8. The time now is 09:37 PM. |
