Need to raise the passenger side rear ride height half an inch
My car is sitting just about a half an inch higher on the drivers side rear than on the passenger side. Can anyone tell me how to raise the passenger side ride height using the torsion bar adjustment bolts located behind the rear tire? there are 2 lots there, I need instructions.
There are lots of posts on here on how to do a corner balance at home. Search on "corner balance" and see what comes up.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Walter is right. Your car could be perfectly balanced but the height is not exact...pretty common scenario. It is more important to be balanced than have the height matched.
If your balance is off, a simple adjustment may not be so simple. Depending on the year, you may no adjustment at all on the springplate or you may have no adjustment left and will need to reindex the torsion bars.
Tony G 2000 Boxster S |
cycling has-been
to answer to your original post, this might help.
there is also a height adjustment bolt at the back of the front a arm. as you raise or lower, do a road test between adjustments to settle the suspension, then keep measuring each fender again, as an adjustment at any corner will effect the other three. Bill K (photo 'borrowed' from another Pelican)
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 11-20-2009 at 12:09 PM.. |
Does it sit level with you in the car? That should be the way the car is corner balanced?
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
Before you adjust anything, isolate the front end from the rear using a tripod lift (see archives). Knowing the opposite end isn't affecting the ride height, you can proceed with the suggested ride height adjustment methods and maintain closer corner balance.
Sherwood |
Put someone in the drivers seat at about your weight then measure. Also look at the right front measurement; raising the right front will lower the left rear.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
You'll probably be glad if you first go buy a ride height wrench. A half inch is a lot of difference. We're not talking fine tuning here. If the clamp nut is really really stuck, then you may have to remove the spring plate to blast it off with heat/impact wrench. Once the clamp nut is loose, the adjustment is pretty easy.
