WydRyd's Avatar
Cause of a wobbly steering whee?
What are the possible causes of a wobbly steering wheel?
The wobble/vibration ONLY occurs violently between 100km/h - 120km/h (i.e: 60mp/h - 75mp/h). Quite annoying on the FWY since the limit here is 100km/h on most FWY's
SO, I either have to stay under 100, or go over 120!!!
Is this an easy fix?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-11-2005, 11:46 PM
Monkey Wrench
Spede's Avatar
Wheels need balancing.
Old 08-11-2005, 11:51 PM
WydRyd's Avatar
Sorry, forgot to mention that I can actually wobble the steering column up'n'down with the vehicle stationary.
Merv
'89 911 Turbo Cab
Old 08-11-2005, 11:52 PM
hey merv
you may also need a new steering column bush/bearing. this thread may shed some light.
Steering column bushing ordered...any tips?
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 08-12-2005, 12:00 AM
Slumlord
Porsche_monkey's Avatar
Are you sure the welds aren't broken in the spokes. The wheel is 'loose' front to back and makes a clicking noise.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-12-2005, 05:09 AM
Check the steering column bushing right behind the steering wheel. Simple and cheap to fix.
Old 08-12-2005, 05:56 AM
scottb's Avatar
Originally posted by obrut
hey merv
I had a similar problem, though not as extreme. The steering column bushing did the trick. It's an easy (one-beer) job.
1984 Targa
Old 08-12-2005, 09:26 AM
Nickatnyt's Avatar
If it only happens when braking then it is very likely warped rotors. If all the time then what everybody else said is probably the case
1982 SC...Guards Red + Linen
Old 08-12-2005, 10:58 AM
Unregistered
sammyg2's Avatar
Replace steering wheel bushing first, 15 minute job if you have an impact gun.
Then have the tires checked for balance or run out. Sometimes tires have chord seperation and will cause the shaking, or they can get flatspotted and no amount of balancing will take care of it. Don't ask how I know that one. You haven't locked up your front tires lately, have you?
Old 08-12-2005, 11:18 AM
WydRyd's Avatar
Thanks for the suggestions guys. Nope, haven't locked her up lately.
Will have to check the bushing as suggested. Don't have an impact gun tho
Thanks for that URL too. Very informative
Merv
'89 911 Turbo Cab
Old 08-12-2005, 07:38 PM
scottb's Avatar
No worries...I did mine with a 1/2" ratchet wrench and a torque wrench.
1984 Targa
Old 08-12-2005, 07:46 PM
Thunder Punk's Avatar
I'm experiencing the same thing. Had the wheels balanced and the wobble is now at 70 instead of 80 mph.
The problem started after I installed my new 19" wheels and tires. It may have done it before with the 16" Fuchs but nowhere near as bad as it is now. I cannot move my steering column up or down though. Do you guys think it could be the bushing if the column doesn't move?
I was thinking that maybe the extra weight of the new wheels may be causing the shocks to rebound improperly. Any suggestions about suspension that may help if it turns out not to be the bushing?
Old 08-12-2005, 09:29 PM
