MBruns for President
Identify these gaskets and win
My gratitude anyway...
Ordered the "top end" gasket kit. Basically you get a bunch o'gaskets and o-rings for you to do a top end = make sense, right? Well, you get the gaskets - sandwitched between some cardboard and plastic - some in seperate bags. Anyway - having some difficulty identifying these - help - they were all in one bag together...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
The top right one looks like the o-ring for the oil thermostat.
1989 C4 Coupe 1975 911 carrera 2.7rs Sold 1978 911sc Sold 2001 Boxster S |
Nope already got that one with the breather gasket (that one made sense) Thanks for playing...
Red one to distributor?
Ok - well #1 is the gasket for the intermediate shaft cover
Automotive Monomaniac
That one in the middle on the bottom looks like a quarter.
Did I win?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
numbered picture...
Senior Member
Not to be picky but aren't 4 of the 5 really o-rings
so the one in the upper left is a number 5 o-ring..... Ok all kidding aside #4 looks like the o-ring for the throttle body
78 Euro 911sc Targa 03 Hayden SCWDP |
My guess is that no. 4 is the O-ring for the oil filter console. But that's not really part of the engine, is it?
Sherwood |
2 is a muffler gasket. It's made from graphite - it goes between the cross-over and the cat. Part number is 911 111 189 03. When the top end comes apart the muffler comes of. This is why it's included. What did I win??
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 Last edited by ischmitz; 07-31-2005 at 12:08 AM.. |
I agree that #2 is an exhaust gasket, #3 appears to be an oil return tube o-ring seal, #5 o-rings look like they might be for the block mounted oil cooler. Guessing at #1 to be the distributor base seal and #4 could be for the throttle body.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Thanks - yes, O ring would be more appropriate. Thanks for the info
1.) intermediate shaft or t-stat seal.
2.) exhaust gasket. 3.) case oil-passage seal? 4.) #8 bearing o-ring? 5.) timing chain cover/tensioner seals? Only other guess is they are for stuff your car doesn't need, like smog pump or turbo system seals. |
Eric - #1 is correct Intermediate shaft
#2 is exhaust (don;t need) #4 is throttle body seal #3 case oil passage - it's not big enough
Hmmm, only other guess on #3 is an o-ring for something your particular car doesn't need, like smog pump or a turbo system seal maybe?
Oh, and what about #5? Last edited by Eric Coffey; 07-31-2005 at 12:52 PM.. |
Unregistered
#5 looks more like an 8-ring than an O-ring.
#2 has been in the last 3 topend gasket kits I bought. Ya, its and exhuast gasket all right, but it does not fit any motor up to 3.2. I believe it is for a 964 style exhuast that fastens with clamps and not flanges with bolts. I have some if anyone needs them!!
![]() Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
