Replacing threshhold strip
I am thinking about replacing the rubber threshhold strip on my 89 Speedster (I'm running out of things to replace) and was wondering if it is glued in? Thanks!
The replacement will have a couple strips of double sided sticky pre-applied. Just get the old one out, clean up the sill and put the new one in.
I like to pull the strips off of the adhesive a couple inches and get the rubber lined up. Then gradually pull the rest of the backing off as you work your way down to make sure it is aligned perfectly. |
| All times are GMT -8. The time now is 07:13 AM. |
