Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Bike Rack for my 911
I am tired of taking the wheels off my bike and stuffing it in the back of the 911...and top that with the fact that my downhill bike will not fit at all.
I was thinking of mounting a bike block on the rear bumper area and a strap at the top of the rear glass (as seen on the extra wide R-Gruppe monster) for a minimal approach.
Ideas on how to mount this? I would use two bike blocks, one for a regular QR and one for a 20mm TA on the downhill bike.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 07-30-2005, 11:42 PM
89turbocabmike's Avatar
I've got a couple ideas for you K9:
1.
or this,
2.http://www.sportsimportsltd.com/unliplmobica.html
Old 07-31-2005, 12:47 AM
SLR SLR is offline
SLR
I'v been thinking about this my self for some time now and come up with an idea.
Take one gutter mount roof rack and fit a QR to it one on each side just in from the ends say about 8". and have some foam (closed sell foam) on the whale tail near the rubber bit, place the forks in the QR fitting on the roof rack fitted to the rear of the roof (need to fiddle to find the best spot) and the rear wheel sits on the foam with a tie down to stop it moving about. It works.
The roof rack needs to be a good one, and can easily be removed.
Good luck Steve.
Old 07-31-2005, 02:45 AM
Phoenix's Avatar
k9:
Another option would be to use either standard Yakimo or Thule racks with bases designed for cars with rain gutters (just be sure to use rubbers hoses where the bases meet the paint). These mounts work great for two bikes as well as anything else you may need to schlep around.
Here's the set-up I use:
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 07-31-2005, 07:25 AM
Montana 911
k9handler's Avatar
1.
That is what I was looking at...just don't want to destroy my reflector to mount it.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2005, 07:03 AM
I ordered the plate mount from Sports Unlimited. It was back ordered for months with no response. I canceled the order and got it elsewhere for just under $200 and it came right away.
FYI, if you have a bike that does not have a right angle, 90 degree, between the horizontal and vertical tubes, you will need to modify.
FD
Old 08-01-2005, 07:13 AM
K9, how about a 3/16 - 1/4" aluminum metal plate mounted behind the license plate that extend's up to allow mounting the fork mount to it?
Old 08-01-2005, 05:38 PM
I would enjoy understanding how the bike is mounted on the other side of the engine cover on that first concept.
Old 08-01-2005, 05:54 PM
me too. i would like one for a cab. I have thought about the trailer hitch type with a removable trailer hitch (maybe 4 bolts to the underside of the AL bumper).
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 08-01-2005, 08:55 PM
moazam's Avatar
Send a message via AIM to moazam
Uhh..wow. That is something!
From looking at it, it seems the bikes front fork goes into the mount, and the bike+rear wheel simply ride behind the Porsche as it drives! Wonder how the bikes rear tire does (in terms of tread) at those speeds.
2014 Porsche Cayman S
2001 BMW 525i Touring
1996 Porsche 911 (Gone to Germany)
'86 911 Carrera (Gone to Aruba)
Old 08-01-2005, 11:23 PM
SLR SLR is offline
SLR
[IMG]IMG[/IMG]
This is just what it looks like. only need one roof rack, this ones only siting there but you should get the idea.
Steve.
Old 08-02-2005, 02:01 AM
jdowty3's Avatar
I found a Saris Bones rack fits perfect. Great for a Cab where a roof rack isn't an option. It would probably even clear the tail on Steve's car.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-02-2005, 05:24 AM
Montana 911
k9handler's Avatar
No...I think the bike is mounted the oposite way with the rear wheel resting on the back glass. This is where I think a strap could hold the wheel in place.
89turbocabmike...that is the plan, thank you for the idea.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-02-2005, 06:57 AM
