Removing door window frames?
I need to repaint the door frames on my 911, (the black bits) there are bolts at ether end and screws at the top. I want to leave the glass in place.
is it hard to get the rubber seal back over the 1/4 light glass when reinstalling the frame? Thanks Steve. |
Re: Removing door window frames?
You have to take the door panel off. Inside the door are some bolts ( or screws). Now that I think about it I think the screws are accessable on the out side of the door under plastic plugs, I'm not sure now. When you have them out just lift up on the frame the door glass will stay. the "vent" glass will come out with the frame. The seals are easy to replace. I've done this, The paint did not work for me, even the self etching primer failed to stick. I will do it again, but I'll get the frames powder coated.
There is one bolt inside the door that must be removed, so the door panels must come off. The other 5 bolts are under 20mm placstic plugs in the door frame.
| All times are GMT -8. The time now is 10:53 AM. |
