-   -   How often do you change Mobil1? (http://forums.pelicanparts.com/porsche-911-technical-forum/233882-how-often-do-you-change-mobil1.html)
GaryR 08-02-2005 07:04 PM
Originally posted by PorscheG
Too often,
I bought the car 1 year ago and already changed the oil 4 times.
I put 3500 mile in that interval.
I guess I get bored and start doing something. Changed the plugs
3 times as well.
Hey, WTH.. pull the engine and polish the cylinder fins so air can pass through with less turbulance! Lexol the SP wires! Simichrome the case!
Doug&Julie 08-03-2005 05:01 AM
My car leaks so much oil, it kinda changes itself! :p
OK, seriously, 5k or once a year (not necessarily whichever comes first). More like once a year...
rcm 08-03-2005 05:50 AM
Every 5000 in the Audi and Mini. Both are high revving 4 bangers. 911 gets it once a year before storage but, I use regular oil in that.
That will be lucky to see two thousand this year.
RickM 08-03-2005 06:28 AM
Too often,
3 times as well.
I'll take your used plugs and oil when you're done.... ;)
ANTONIO 08-03-2005 05:07 PM
I guess it all depends where you live at, in my side of the world(Puerto Rico),there is a lot of humidity,so if you let the car standing still for weeks at a time,then you need to change it at least every 3000 miles, in my case I use a better oil(IMHO) that is Royal Purple,cheers,Antonio.
Tyson Schmidt 08-03-2005 05:36 PM
3 or 4 times a week.
Oh, you mean on my car.
Every 5K or after every race.
catser911 08-03-2005 08:27 PM
plugs
Too often,
3 times as well.
Messing around with the spark plugs too much may ruin the thread in the cylinder heads.Then the fun begins!
