North Coast Cab's Avatar
Anyone Have 2 Carrera Oil Coolers
Anyone running a Carrera oil cooler in each fender? I need to bring my oil temps down and adding a front cooler would require a new front bumper. Thinking of reomving the washer reservoir and adding a second Carrera cooler. What do you think?
John
1985.5 944 GTS
Old 08-01-2005, 02:38 PM
MBruns for President
JeremyD's Avatar
Wow - really? I didn't have cooling issues with my car even running back to back sessions at Sebring when the on track temps were over 100 degrees. Sure everything is working up to snuff?
Old 08-01-2005, 03:07 PM
John,
Your 84 probably doesn't have the fan on the cooler and that could help quite a bit. I know my 85 doesn't have it and I am going to ad it. I think it became standard on the 86's. I would go that route as well as maybe figure out how to funnel the air to the existing cooler. Many threads on how to do that. That should be more than sufficient.
Ladd
Old 08-01-2005, 03:42 PM
klaucke's Avatar
You might try other solutions that can be quite effective, such as ducting, a fan, finned oil lines, cleaning the engine mount cooler, removing fog light, etc. These can all lead to some good reductions in temp, especially when done together.
Twin Carrera coolers is doable, a search will provide some info:
Two Carrera Oil Coolers for the 3.6 Finished! - LONG
Old 08-01-2005, 03:51 PM
chrisp's Avatar
Get air to it. I had a carrera cooler on my SC and it ran at 220-230 on really hot days. I put in a 44 row Mocal front cooler which is probably not as effective as the Carrera unit (smaller but fits better up front) and on similarly hot days I am running 200.
With the right air flow you don't need huge/multiple coolers.
'83 SC
Old 08-01-2005, 04:02 PM
Track days with air temp in mid 90's I reached 248D. I have the factory installed Carrera cooler, but it is the early one with just tubes and no fins or anything. I remove the fog light and have blocked off the bottom to funnell air in. I also added a fan, but that only helps when idling or in traffic. The only thing I think I could add would be a stoneguard to block a little in into the cooler.
John
1985.5 944 GTS
Old 08-01-2005, 06:13 PM
RETIRED
Joe Bob's Avatar
Try a larger cooler.
2012 ML350 3.0 Turbo Diesel
Old 08-01-2005, 06:35 PM
Makaio said the turn sig scoop is good for 10-20deg on his Carrera.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-01-2005, 06:38 PM
I,ve installed a second cooler on the drivers side for a 3.6 conversion. Theres a very good thread by" surflvr" I think. It sounds like you have the 28 tube Euro/ROW cooler ,not the late Carrera cooler. I,d install a fan and then cut some holes in the back of my headlight bucket and remove the light for the track if air flow is really the problem.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 08-01-2005, 06:47 PM
Barrpete's Avatar
87 was the first year for the auxiliary fan on the carrera oil cooler. Here in Tucson when temperatures approach 110 my oil temps approach 250 if I drive much in stop and go traffic with the AC on - so I don't. I just ordered an aftermarket fan and install kit from Elephant Racing for $170 complete with relay, wiring, fuse and thermoswitch that's adjustable from 170F to 210F. I'm thinking of using the 170 setting to set the fan to come on hopefully that's not too low.
They also have lots of oil coolers of all sizes and shapes.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 08-01-2005, 07:29 PM
SC-targa's Avatar
Originally posted by North Coast Cab
I have the factory installed Carrera cooler, but it is the early one with just tubes and no fins or anything. john
You really don't have the Carrera cooler at all. That's the 28 tube brass oil cooler. A radiator type cooler with air flow will do better at the track.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 08-02-2005, 05:13 AM
