Spacer question
When re installing spacers do I need to torque them ? Is so what #. Should I use some sort of lock tite ? Just curious
To what spacers are you referring? Maybe a picture would help.
Doug |
wheel spacers
There are different varieties. Some that are actually adaptors, which bolt to the existing hub and have their own studs. Some that are true spacers and just slip - on to the studs. The latter does not use loctite, but should be torqued.
Again, maybe a picture would help. Hard to read your mind. Doug |
sorry dont have pic right now but they are spacers with studs-that bolt to existing hubs
Torque them just like wheels.
Anything specific on torque
I'm thinking 70 to 75 ft-lbs, but someone else should clarify.
tx
All 911 lug nuts prior to 964 have 94 lb-ft torque spec!
I was waiting in great anticipation of Warren diving from the top turnbuckle to drive an elbow into DWSD's temple. Thank you for the show, Warren!
OUCH - some times we all learn lessons the hard way - that hurt my temple!
Kidding aside, I believe I did suggest someone should clarify. |
Definitely no knock intended on you or Warren, DWSD. I just get a kick out of seeing Warren in action. Don't know why...it just makes me smile. :)
No question - Warren is the MAN! I'm not trying to be Warren, either. Just trying to help. I will qualify my answers if I'm not 100% sure.
Doug |
| All times are GMT -8. The time now is 11:48 PM. |
