Part Number ? Oil line bracket
I did a search but did not see exactly what I need.
One of the brackets that holds the solid oil line on the front of my engine is broken. This line is the one that arcs under the gearbox and goes either to the tank or the cooler and the bracket is the one that mounts to the front of the engine on the paseenger side. Right now the oil line is resting on the passenger side exhaust header. This cannot be good.
I need a diagram, so I can identify the part then order a replacement from Wayne.
Thanks in advance,
Don
72T Coupe - SOLD :-(
Old 08-02-2005, 03:42 PM
I looked at an oil system diagram that Grady had posted in the past. I was able to confirm the line I was talking about is between the tank and the engine.
Thanks,
Don
Old 08-02-2005, 03:55 PM
