-   -   Fuchs"replicas" (http://forums.pelicanparts.com/porsche-911-technical-forum/234207-fuchs-replicas.html)
luvmysc 08-02-2005 09:42 PM
Fuchs"replicas"
Has anyone ever tried these fuchs replicas I see on Ebay?
what are your thoughts of using them on the track(DE, not racing)
any info appreciated.
IROC 08-03-2005 03:34 AM
The only Fuchs replicas I would use on the track are the ones made by HRE. Anything else would be dangerous.
Mike
Driver8 08-03-2005 04:10 AM
I agree with Mike. Fuchs replicas will not hold up on the track. I think Lindsay makes a track worthy fuchs replica. If you are looking at used OEM fuchs make sure to inspect them for cracks, or cracks that have been repaired. Either case they will also not be track worthy,
A
cstreit 08-03-2005 05:26 AM
Fine for the street, big NO on the track!
luvmysc 08-03-2005 07:41 PM
what makes them so untrustworthy? 3/4 of the new wheels out there are cast also.
IROC 08-04-2005 03:32 AM
Searching will net you lots of info on this, but the short answer is that the Fuchs centers gain their strength through the forging process - if you simply cast a wheel with the same dimensions it's not nearly as strong (and there are lots of spectacular failures out there of cast replicas to prove it).
Mike
304065 08-04-2005 08:56 AM
They are too heavy, besides.
Real 6" Fuchs will spin up/down so fast with a Hoosier mounted that you really have to modulate carefully to avoid smoking.
