Torrential rain coming home from work....should I check amything?
The kind of heavy "flood" can't see out the windshield even with the wipers full on....... Continued torrential for about 8-10 miles
Should I check the car for anything particular? Thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Just a few water drops in the engine comp. after inspection. Electrics OK.
Slackerous Maximus
Ummmmm....as a Seattle resident with a TARGA.....unless you saw an ark, don't worry about it....
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
It rains in Germany, I think they designed 'em not to melt.
![]() Yes, I drove my '88 targa everyday in Houston for almost 4 years, that's lots of rain. That's through floods with 6" deep water. You shouldn't have much to worry about.
Designer King
Check under your floor mats for any moisture.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
And under the sound pad, to check the rear window seal
Donnie Currently Porsche-less.....
There is a small drain on the back of the lower seats ( no one seem to know about them ) that you can just pull the nipple out and viola the water is drained
If you can't find that drain holler at me,will ya !
alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Non Compos Mentis
Yeah, right. You just want to see pictures of nipples.
Designer King
What's your point?
Designer King
Sorry, Yasir.
You see... when someone says "You just want to see nipples" as a joke and then someone else chimes in with "What's your point?" then that's a continuation of the joke, because the second person realizes that the first comment, although said in jest, sounds serious, so the second comment, which is also in jest, and sounds equally serious, points out that the first comment is not really serious, and suggests that the activitity referred to is actually not a bad thing. You have to work with me here. and I have to remember to use the smilies. BTW, we said "nipples".
