project 911's Avatar
Priming tensioners
Does anyone know when you need to prime tensioners? I have my original set (not pressure fed) and they have soaked in the parts cleaner. Should they be drained and/or primed with oil before reinstalling?
Any advice is appreciated.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-02-2005, 04:47 PM
you probably killed the rubber seals by soaking in parts cleaner. you need to rebuild them now. in the process, they get primed.
206 637 4071
Old 08-02-2005, 09:17 PM
Thanks John,
I use only K1 kerosene as parts cleaner. Would that make any difference in the possible damage to the seals?
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-03-2005, 04:04 AM
never used it, so i don't know if it will soften and expand rubber o rings like regular cleaning solvent does. my guess is that it's probably less likely to, but....?
206 637 4071
Old 08-05-2005, 08:31 AM
