Somatic Negative Optimist
Do you carefully expand each single ring and move it over the piston into the groove? Is there some trick to it?
Do you prefer to mount the pistons first onto the rods and then install rings? I think that I like to install pistons and then slide the cylinders over the pistons. Yes? What is the preferred ring compressor for 98mm P/C's?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Lisle, Craftsman, and other brand piston ring expander tools make the job lots easier and less damage to the fingertips ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Just slip 'em on before I go home to the wife!
'79 911 SC |
I still prefer to install them with my fingers. (better feel)
As far as a ring compressor goes? I use one that is multi-adjustable. I can't remember if I bought it from Porsche or from Wurth. Its the best! If I remember tomorrow, I'll take a pic of it and post it.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
Update on the ring compressor. The one I use is a Hazet and the part # is 794U-3. They are about $155 bucks and worth every penny. One thing they do not work on that I have encountered. 356 and 912 engines with the oil ring placed low on the piston. Other then that....two thumbs up!
