techguy's Avatar
Porsche Crest Carerra Chain Tensioner - Install Q
I have an early car that I have made the decision to install the Carerra chain upgrade on v.s. rebulid the stock tensioner. After hours of reading I understand that its best to install the updated idler arms for the most security.
Is it possible to install the arms without screwing with the CAM timing? Currently I have the chain double wrapped in 2 spots to prevent even the slightest movement on the CAM. The tensioner and spacer will be easy at this point but what about changing the idler? Will I be asking for trouble?
Thanks!
Looks like this:
Disaster averted - chain tensioner update
TechGuy
1972 Targa 911T/S 2.7
PCA Upper Canada Region
Old 08-04-2005, 07:40 AM
techguy's Avatar
bump..parts are going in tonight...any ideas?
TechGuy
Old 08-05-2005, 05:46 AM
David's Avatar
If you put a wrench on the cam and hold it while replacing the tensioner you should be fine. Before you remove the tensioner, be sure you have a feel for which way the cam is going to try to rotate when you remove the tensioner, this way you'll be ready for it.
Old 08-05-2005, 06:35 AM
As long as you keep the cam sprocket from skipping a tooth you can replace the idler arms.
-Andy
Old 08-05-2005, 03:14 PM
yes, you can use zip ties.
John Adams
1980 ROW 911SC
Old 08-05-2005, 03:18 PM
