Search looks to work much cleaner than before.
However, If I look up oxygen sensor I get a page that DOES show sensors, but not for 84 through 89. If I didn't notice the "Next 30 results" tucked away amongst alot of other info I might not think you carry them. In fact the search results only occupy a fraction of the page. Accessories, related tech forums, other sections and refine your search also occupy and compete for the space. While I think cross selling is an excellent idea ....IMO....I wouldn't offer it up until all the results of what someone is asking for are shown. |
fuel pumps
Wayne:
searched for fuel pumps found what i wanted no problems gary |
What about combining the forum search and web-site search so:
(a) the UI is simpler (I always accidentally try the web site search when I want the forum search) (b) give you the opportunity to sell more. If I search the forum looking for how advice on how to install brake pads, or what brake pad is best, it would be interesting to also see what PP sells. Or you could do that evil dynamic linking stuff and link any mention of Pagid or wipers, for example, back to a search on "wipers". Might be semi-annoying as an end-user, but might also be sometimes useful and also help monetize the forum for PP. Just some thoughts - looks good so far! -Steve |
-Wayne |
I agree, the search is very hard to use on this site, too many results that do not pertain to the search, coming from 15yrs of PHP MySQL experience you def could improve the search criteria in order to more accurately look through the catalog, i fins it easier to drill down the sub-sections to find the part or most of the time i have to call to ask if you carry the part, and am usually directed to the right part that was not found by the search
I don't really like the implementation in the "search this forum". I know when I'm looking for information versus when I'm looking to buy some new parts and the whole process is slowed down considerably when I am searching the forums for some info. (dang this dialup....)
But hey its your ballgame! I've seen plenty of times where people in the used parts forum were reminded that you had a part they were looking for in stock. Ken |
-Wayne |
Maybe a check box to Search Parts should be added instead of defaulting to that option.
http://forums.pelicanparts.com/uploa...1123556543.jpg -Wayne |
On a side note, I don't think the engine bay fuse cover is in our catalog, so it wouldn't show up either way...
Just trying to make it a little more intuitive... -Wayne |
Hi Wayne,
I don't know if we decided if the search engine is only searching for parts or the forums or both, but I too would love to be able to search on two character strings in the forums: H4, SC, RS, O2, CV, etc. Can that be changed? Also, if it can be done, the search forum should default to the one you were in when you clicked search and not 'all open forums'. Not sure if either of these can be done, but they would be welcome. Regarding the parts searches, I was looking for CV joints recently, and didn't see the joints themselves listed, only rebuilt axles and boots. When I went through your wizard though, it listed the joints at around $71 ea. I didn't fully document my search terms, etc., but thought I'd throw that out there. ianc |
Wayne,
Here is one that I tried because I remember it being very hard to find the first time I looked for it. I was looking for the little rubber mushroom shaped bushings that go on the rear (911) shocks. If I remember correctly (its been several months) I couldn't come up with a description that worked, so I searched on the OEM number from PET. That got me your number: c-333-521-00, which is the correct part. Your description reads: "Rear Shock Mount Ring, 2 per shock, 912/911/911 Turbo (1965-89)" Searching directly on your part number also yields the correct result. However, searching on the string 'Rear Shock Mount Ring" yields two and a half pages of results, none of which is a Rear Shock Mount Ring. Oddly enough, the first two items in the results set are "Rear Shock Mount Bolt" and "Rear Shock Mount Washer" Joe |
I previously bought the 36mm ride height adjustment flat wrench from Pelican. It was a nightmare to find using search. I searched again with the following results,
1. search terms 'flat wrench height' = 1st result 2. search terms 'flat wrench' = 11th result on second page, some of the results on the first page were not intuitive e.g 'flat washer' 3. search terms 'flat wrench suspension' - hundreds of results, could not see it Better than before but not perfect. Site search is a nightmare in my experience. Do you do any Search Engine Optimization? Whenever I get Pelican results in search engines they seem to be for the technical articles which is not going to drive your revenue. If you have tens of thousands of links out there they are not going to surface to the top of the big search engines. |
The two-word search is somewhat out of my control - it's a limitation of the board's software. The search program doesn't index any two-character words, in order to keep the speed of searching up. The forums search should automatically search the same forum you're in at the time. The only exception is after you place a post - then the whole system doesn't get good feedback, and defaults to the whole forum. -Wayne |
-Wayne |
Here at Pelican, we have adopted a longer-term strategy. By providing good, quality content, we drive traffic to our tech articles, which then feeds the catalog and this BBS. Our goal is to get people to bookmark our page and then come to it first, instead of searching aimlessly on the Internet. So far, the strategy appears to be working pretty good! :) -Wayne |
One aspect of this search engine improvement is trying to figure out synonyms and similar phrases for items. For instance, the search engine recognizes "rotor" and "disc" as synonyms. Also, mispellings too, like "Boxster" and "Boxter". The trouble is, that even if you called up our sales rep, and told him, "I need the cover that goes on the front of the trunk compartment and is made of metal and cardboard" - he would have to think about that for a sec. There's almost no way to search for that item, unless you have some type of picture system like PET... -Wayne |
It's definitely better, but I still have an occasional problem. For instance, I just searched for "hood shock retaining clip" (which I didn't think you actually carried!) and found what appear to be the right parts (which I will order!) but I got a strange artifact with the checkbox section on the left being much larger than it is apparently intended to be:
http://forums.pelicanparts.com/uploa...1123586579.gif My box runs Linux and I'm using Mozilla. (It should show up in your access logs as "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.4.2) Gecko/20040308".) For what it's worth, I find that yours is one e-commerce site that consistently works pretty well with this browser and OS; I don't do business with ones that don't! Thanks for not using nonstandard Microsoft-specific stuff on the web. Also, one small note about the forum picture upload function. On the entry screen, it says "Valid file extensions: gif jpg png txt zip bmp jpeg" but when I just now attempted to upload a png screenshot, it was rejected with an error message indicating that it only accepted jpg and gif, so I changed the format to gif and uploaded. Something's a little awry there. |
| All times are GMT -8. The time now is 01:52 PM. |
