CIS Air Flow sensor plate Sticking?
I have an '81 SC. Normally, when I turn on the key (without starting) everything is quiet except for the normal ignition box buzz. However, sometimes, when I turn the key on, the fuel pump also comes on (car not running). When the car starts, it tends to stumble for a few seconds when this happens. I think there is a fuel pump safety switch that only activates the fuel pump when air is flowing through the Air Flow Sensor plate (ie. the engine is running). Could my issue indicate that the air flow sensor plate is sometimes sticking slightly open, thereby allowing the fuel pump to come on when not running, and causing the stumble for a few seconds? Thanks for your help.
Mike
2016 Porsche GTS Club Coupe (60th Anniversary)
2007 Porsche GT3; 2014 Porsche Cayman S
1981 Porsche 911 SC; 1988 Porsche 944 Turbo S - Silver Rose
2010 Audi Q7 TDI; 2002 Audi A6 4.2 ; 1971 El Camino; 1966 Chevelle SS 396/360 HP; Spec Miata racecar
Old 08-09-2005, 08:55 AM
