-   -   How do I remove a broken Lug nut??? (http://forums.pelicanparts.com/porsche-911-technical-forum/235057-how-do-i-remove-broken-lug-nut.html)
K. Roman 08-08-2005 12:41 PM
I'm trying to remove my front drivers side wheel and one of the lug nuts broke off leaving the base in place inside the fuch, still screwed in very tight. I've sprayed it with Rust Off, and have had no luck removing it. Anyone with a "bright" idea???
Joe Bob 08-08-2005 12:44 PM
Some people have luck with a deep hole saw that fits over the shaft of the threaded stud.....spin it up and cut carefully.
K. Roman 08-08-2005 12:49 PM
Thanks,
what size do I use? The lug is a 19.
si Banker 08-08-2005 12:51 PM
Broken lug nut
Buy a hole saw, as deep as possible, but just bug enough to fit over the stud. The hole saw will cut the base of the lug nut and you will be able to remove the wheel and then with the wheel off you could then replace the stud.
In the future you should keep a coating of lube on the studs.
Joe Bob 08-08-2005 12:54 PM
Take a pair of calipers....I don't have my book in front of me....and measure the STUD....get a hole saw the size of the stud.....I'm assuming it's broken off all the way down toward the bottom up against the wheel?
Anyways, get a couple of them, and try to cut with the drill on reverse....the heat and the directional torque may break it loose. Hit the stud with PB Blaster or Kroil before....don't use WD-40 that stuff sucks....
Gud luk....
imcarthur 08-08-2005 12:58 PM
Just did one 2 weeks ago. 3/4" deep high quality hole saw. Remove the guide bit & saw carefully.
http://forums.pelicanparts.com/uploa...1123530918.jpg
http://forums.pelicanparts.com/uploa...1123530933.jpg
Lube the studs lightly & use an anti-seize on the bevel part of the lug nut to prevent future problems.
Ian
Joe Bob 08-08-2005 01:03 PM
OH BTW.....IF there is any of the hex left....SOMETIMES an SAE 11/16th socket can be beaten on and will have enuff bite to crack it loose.
john walker's workshop 08-08-2005 01:08 PM
the remaining thin threaded shell is removed with a pencil sharp punch and hammer. the wheel won't come off until you remove the shell.
vash 08-08-2005 01:40 PM
i purchased 4 brand new lugnuts and put my locking ones in a box. i didnt need the potential aggrevation.
k roman, when are you planning on doing this? i wanna see....
imcarthur 08-08-2005 01:44 PM
I didn't have any luck moving it with a punch. When I got down to what is pictured above, I took off the rest of the lug nuts & the wheel popped off with that remainder still wedged in the wheel. The threads were drilled off by that time.
And thanks to JW for his long-ago post on how to do it.
Ian
Steve87-911 08-08-2005 02:30 PM
I've read about this happening a number of times so I am curious.
Do they typically get stuck and break because someone may have over-torqued the lug nut long ago?
imcarthur 08-08-2005 02:33 PM
Mine was torqued correctly & only on for 2 months.
Ian
88911coupe 08-10-2005 04:09 PM
I had this happen when they ignored my request to use a torque wrench. The hard part is getting the leftover metal out of the threads. I finally snapped and beat the hell out of it till enough metal was removed and just took the whole hub to Rennsport here in Tulsa and had new lugs installed. Much faster and was not too expensive at all.
K. Roman 08-11-2005 11:14 AM
The hole saw worked like a charm. It took about 3 minutes. Popped right off. The bolt will have to be replaced though, I sort of dug into the threads a little.
Thanks for the knowledge..!
Joe Bob 08-11-2005 11:35 AM
Glad it worked out....
Two Tone 01-12-2007 04:19 PM
This site is so great.
I already know how to fix what just happened to me. I can't believe I didn't think of this myself.
BTW: The nuts were new, lubed and installed by me with a torque wrench about 8 months ago. I just broke 1 out of 20 when removing the wheels today.
Cheers!
douglas bray 09-24-2011 07:01 PM
Just want to thank you guys for your help today. Especially Ian.
Broken Wheel Lock - Rennlist Discussion Forums
