hillelson1's Avatar
Send a message via AIM to hillelson1
why wont my car start
ok well my 1984 wont start i replaced the dme relay and that did not fix the problem. i can smell gas to i think the injection is working fine. it doesn't seem to be getting spark. what can check?
Old 10-22-2005, 08:16 AM
ruf-porsche's Avatar
coil cap and rotor?
Old 10-22-2005, 08:21 AM
Jbabic's Avatar
no spark...make sure its getting voltage...coil wire, not sure if there is a fuse in the loop, but if there is...check that...
Old 10-22-2005, 08:45 AM
does it have a cdi system ? if so do you hear the whine when ignition is on ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 10-22-2005, 09:09 AM
hillelson1's Avatar
i hear a buzzer when the ignition is on then that turns off after a few seconds. i check there is no voltage getting to the coil. what should i check from there?
Love cars lucky i got an early start
1989 911turbo project
1928 rolls royce
Old 10-22-2005, 01:06 PM
kilodawg's Avatar
Could be DME itself. I have an '84 too and had the same symptoms 2 weeks ago. That was my problem.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 10-22-2005, 01:41 PM
Detached Member
Hugh R's Avatar
A few weeks ago, my 84 just quit. Three days at TRE and they diagnosed it as an internally shorted fuel injector. Very rare, very strange, killed all juice to the DME.
Hugh
Old 10-22-2005, 01:52 PM
hillelson1's Avatar
i can here the switches in the dme relay clicking so there has to be power going to it. just replaced the dme relay with one from this website. any other ideas?
1928 rolls royce
Old 10-22-2005, 07:53 PM
