Possible to change oil filter without oil drain?
Hi,
Last weekend after I drained the oil I found that my wife graciously threw the new one away (my fault because I put it next to some boxes) anyway... I had to run to the local parts store and bought a FRAM oil filter. I've read some members don't like it at all, I can't remember the details but basically poor filtration. I'll get the Mahle in the next days so the question is: Can I simply replace the oil filter without doing another oil change? Thanks -J |
Sure you can.
Non-Posche filters may not have the bypass valve allowing oil to flow in the event of an obstruction. Just a bit of insurance. I did the same thing not long ago when a mechanic (who I will never use again) installed a cheap filter after doing a check to see if I needed a valve adjustment. The filter is about the highest point in the oil system. Not much oil will spill out when you change just the filter. |
Is there a connector that will allow for two filters to be set-up? I know it is possable in other engines (diesel and a few gas)? I have acces to a grat by-pass filter
LubeMaster77: I have seen them too in other applications but I wonder if a double filter would impose to much pressure in the system. Is that what you refer as a by-pass filter or something else? If your idea fly then someone will start producing them for sure.. Thanks -J |
The by-pass filter has been around since the 30's but a connector that filters a portion always that comes off the spin-on is something I have only seen in diesel applications. Not sure why it would work in gas engine apps. I will have to explore the option.
too much pressure (?)
- are we talking serial or parallel here? I thought the idea was to filter the bypassed fluid? |
