-   -   Muffler clamp options - mcmaster.com part # included (http://forums.pelicanparts.com/porsche-911-technical-forum/235307-muffler-clamp-options-mcmaster-com-part-included.html)
DW SD 08-09-2005 05:06 PM
I used the below clamps very successfully. I'd strongly recommend them. McMaster part # 8946K38. I had to modify my muffler brackets (on the back of the engine to follow the muffler's diameter a bit. The modification took 10 minutes, a hammer and an anvil.) They are very high quality, stainless + yellow-zinc plated bolt hardware w/ nyloc nut. Good stuff. I tried Porsche stuff, but the muffler was a different diameter and nothing fit this nicely.
These are lightweight and potentially great match for many muffler applications! I bought the clamps from Mcmaster.com:
Part Number 946K38 Constant-Tension T-Bolt Hose Clamp - 5-15/16" To 6-1/4" Range, 3/4" Band Width $6.83ea. $13.66
http://forums.pelicanparts.com/uploa...1123631682.jpg http://forums.pelicanparts.com/uploa...1123632181.jpg
gost 08-09-2005 05:48 PM
Nice....very nice!! Thanks for the info!
billyboy 08-09-2005 07:23 PM
original
Not OEM German, could cause catastrophic engine failure and death:rolleyes: PS, I'm JK, great idea, I used some stainless bandit,but it's not so easy to take apart.
Formerly Steve Wilkinson 08-09-2005 07:45 PM
A Nyloc nut on a muffler clamp?
Stephan
mb911 08-09-2005 08:02 PM
works well. Thanks to doug's suggestion I sell these with all my kits! Thanks again doug. Infact just got an order today for 100 of those exact size and everything
mb911 08-09-2005 08:03 PM
oh doug show me a side shot of that car. Man I love the look of that!. Maybe after a few million sales of mufflers I will make one like that!
billyboy 08-09-2005 08:15 PM
http://forums.pelicanparts.com/uploa...1123643600.gif They are not normally nylock on those t-bar clamps, they are called flex-top nuts....all metal.
Formerly Steve Wilkinson A Nyloc nut on a muffler clamp?
mb911 08-09-2005 08:18 PM
the ones I get are nylocks but they hold up on my car!
KTL 08-09-2005 08:20 PM
Looks alot like a Clampco brand band clamp. Bet you got 'em much cheaper from McMaster! I love that place. Seems like they have everything and the online catalog flat out rocks.
mb911 08-09-2005 08:28 PM
these things are made in rockford il called something like rockten company I don't remeber
DW SD 08-09-2005 09:44 PM
Ben,
I'm glad these work out for you! Here's the side shot. Nyloc seemed like the wrong solution (plastic and heat don't mix), but I've checked my, run it hard and haven't had any problems. Worst case, I could use a jamb nut or replace the nut with Billyboy's offering.
I've actually been buying a lot of hardware from McMaster. I bought M6, M8 and other bolts and nuts for use all over the car. It is so cheap to replace bad hardware when you buy in bulk.
http://forums.pelicanparts.com/uploa...1123648848.jpg http://forums.pelicanparts.com/uploa...1123648886.jpg
Independent of the self promoting photos: I really hope this helps! This is an awesome board and its great to be able to search the archives and find good solutions to one's problems.
Doug
gerard vaglio 08-09-2005 11:14 PM
That has got to be one of the best looking cars I have ever seen!
What color is it? Do you have any pics of the interior? How long have you been working on it? You have excellent taste.
If I continue to flatter you will you let me drive it?
I'm in the process of rebuilding my 3.0 out to a 3.2. The 915 is already rebuilt and the car was originally silver. I'd like to someday end up close to where you netted out with this car, can you direct me to any threds about your process?
mb911 08-10-2005 06:06 AM
doug if you ever decide to sell it let me know!
Danskman 08-10-2005 07:44 AM
You can also reuse the original clamps on a larger diameter muffler by replacing the original bolt with a bolt about an inch or so longer. Worked for me.
DW SD 08-10-2005 07:52 AM
I thought this may be valuable to share, for those who use different muffler sizes, but still want similar clamps.
Garry wrote:
"Thanks for the write up on the muffler clamps. I am just now looking for a solution and this might be it. I wanted to ask you if you are using a maxflow as it looks similar to mine and I am wondering if the clamp size would work for my maxflow I am fabbing up for my 3.6 conversion."
I used one of Ben Mcfarland's mufflers. (MB911 on the board). The clamps are made and sold in a wide variety of diameters. I temporarily installed the muffler, using zip-ties and wrapped them around, tightening them as I would the clamp. I then cut it loose and laid it flat to measure their length. I believe the clamps are offered in diameters, so I divided by 2 pi (to go from circumference to diameter) - you should come up with the right size.
Again, hope that helps!
Doug
DW SD 08-10-2005 08:43 AM
Gerard,
Thanks a bunch! I'm very pleased. The color is BMW two stage titanium silver. I did all of the work over the last four months or so. That includes oil cooler install, re-wiring most the car, interior, complete front and rear suspension, exhaust, engine tune-up, shifter rebuild, brake rebuild, fuel line replumbing.
You can check out these threads or search on my user name:
http://forums.pelicanparts.com/porsche-911-technical-forum/224453-custom-sparco-seat-mounts-install-w-pics.html - this one shows the interior and custom seat install that I did.
http://forums.pelicanparts.com/porsche-911-technical-forum/229841-project-pics-all-four-back-corner-balance-early-rsr-look.html
http://forums.pelicanparts.com/porsche-911-technical-forum/233357-nice-parts-tarett-engineering.html
suspension:
http://forums.pelicanparts.com/porsche-911-technical-forum/226650-71-rsr-interpretation-project-update-4-w-pics-zinc-plated-rear-susp-bling.html
http://forums.pelicanparts.com/porsche-911-technical-forum/220706-update-3-another-rsr-clone-socal-bit-o-suspension-bling.html
exhaust and wiring: http://forums.pelicanparts.com/porsche-911-technical-forum/217238-rsr-look-project-update-wiring-mb911-exhaust.html
KTL 08-10-2005 10:53 AM
Isn't circumference = (pi) x D = (pi) x 2R ???
So you'd divide the length by only 1 pi to get the diameter........
:D
That is an exceptional looking car for sure! Nicely done.
DW SD 08-10-2005 10:58 AM
KTL - YES!!!
oops, didn't check my work. Thanks for the review. Hopefully, someone else would catch it before ordering the wrong size.
Doug
Rufblackbird 08-11-2005 12:12 AM
thanks for the info Doug! I haven't been running muffler strap/clamps since day one...maybe I'll check mcmaster.com out. :)
Oh, and your 911 is absolutely gorgeous! What size are those Fuchs?
DW SD 08-11-2005 08:39 AM
Jeff,
Thanks! Glad to be of help.
Fuchs are 17x9.5 upfront and 17x11 in the rear.
Doug
GMR911 08-13-2005 07:38 PM
Bought my muffler clamps from Mack trucks- same type of clamp, spring loaded, heavy duty(built like a Mack truck) for about $ 15 dollars each a few years ago. Worked like a charm. Jerry
Joe Bob 08-13-2005 07:47 PM
Can I get a straight fron end shot of your car? I just did a long hood conversion and I have a huge gap between my bumper and the hood/fenders.....I ordered the seal that goes between it....but from what I remember....most long hoods don't have that big a gap.....
http://forums.pelicanparts.com/uploa...1123809544.jpg
DW SD 08-13-2005 08:30 PM
Mike,
Not exactly front on, but close. There is a seal which goes between the top of the bumper and hood and fenders. You can see it in this photo as a line of black.
I'll take another photo square on and close up of the seal.
BTW - I still need to contact you about the graphics trade for the wheel spacers.
Doug
http://forums.pelicanparts.com/uploa...1123990131.jpg
}{arlequin 08-13-2005 11:03 PM
thanks for the heads up on the clamps... (and for doing the work of measuring ;) )
ordered the exact ones you posted and they fit perfectly!
Joeaksa 08-14-2005 07:05 AM
Good info on the muffler clamps. Was looking for something to use on my 3.6 and this is what I needed!
JoeA
Rick Lee 08-14-2005 11:27 AM
God, I want your car, Doug.
