Where to get 9mm OEM fuel hose
After following the thread about fuel hose (thanks to all for their efforts) I'm stymied. I found the 7mm hose at Pelican, but I can't find the 9mm! Pelican has 8mm, but no 9. Everybody refered to the 9mm hose, and that it was available from Pelican, but I can't find it! Help!
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 04-09-2007, 06:41 PM
The hose you want is listed under "vacuum hose" -- its in the section immediately below the high pressure fuel hose. You don't need the high pressure fuel hose, which doesn't have the cloth braiding. You want the 7 mm ID/12 OD hose and the 9 mm ID/14 OD hose.
1969 912/6 Coupe
1970 911 T Targa
Old 04-09-2007, 10:09 PM
Thank you, I saw the vacuum hose in the correct braiding and size, but assumed it wouldn't work for this application.
'72 911T coupe
Old 04-10-2007, 05:03 AM
I assumed it wouldn't work either (and the Pelican salesperson I spoke to wasn't sure), so I ordered some fuel hose via a friend who is a mechanic. His supplier provided Contitech and Veritas fuel hose specified for a 70T. It appears to be the same hose as listed by Pelican as vacuum hose (it looks like the same material as the larger size vapor hose I ordered from Pelican).
1969 912/6 Coupe
1970 911 T Targa
Old 04-10-2007, 08:34 AM
fuel hose
Wrong! Fuel hose and its related systems require the right stuff. We stock 9mm and 7mm for fuel hose. If you can't find it anywhere - call me and I will help.
Old 04-10-2007, 08:40 AM
Perhaps someone from Pelican can chime in on whether the 7mm and 9mm hose they stock is fuel hose. I went with a supplier that stocked the appropriate fuel hose, which is what RPMClassic is correctly recommending.
1969 912/6 Coupe
1970 911 T Targa
Old 04-10-2007, 09:33 AM
You can also try the aircraft supply stores like Spruce Aviation supply co.
They have aircraft quality hoses for fuel and any other application. And they are not expensive.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 04-10-2007, 12:00 PM
Try a BMW dealer. Call the parts counter. Or perhaps a shop that services BMW, Porsche, etc.
Old 04-10-2007, 12:02 PM
