Broke
Westy's Avatar
Question Turn the screw which way?
Took my car out yesterday (because it was under 100 degrees) and although it ran quite well considering what it's been through, it was sluggish on acceleration. Not too bad, but noticible to me. I'm pretty sure it's the same old sensor plate adjustment.
The questiuon is, when I stick my little hex wrench in there, which way should I turn it? I mean, am I lean, or am I rich?
TIA, B.
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 08-15-2005, 09:07 AM
Turn Right for rich and Left for lean . I usually remove the oil fill cap to admit extra air and if it stalls it must be close to lean if Ok its probably a little rich.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 08-15-2005, 09:50 AM
Designer King
Paulporsche's Avatar
You can also use the "Push Pull Method" (search), or , as I do, set it just before the engine wants to stall when you come to a stop, say @ a light or stop sign. If the engine speed dips and then tries to come back up, or if it fluctuates @ idle, the mixture is too rich. You can also use a gas analyzer to set it. JW likes 3.5% CO.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-15-2005, 11:40 AM
