F My Life!
Sorry for the title, but I am a little ticked. I was doing a simple rotor and cap replacement and while pulling the rotor the guts of the dizzy came with it ( see Pic), what do I do now?
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 05-12-2010, 02:24 PM
French Import
zippy_gg's Avatar
Clean, lube, and put back in?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 05-12-2010, 02:28 PM
I can only find one spring, and if you look, i think one of the spring tabs is broken.
Old 05-12-2010, 02:32 PM
I would rather be driving
jpnovak's Avatar
Separate the rotor and look inside the shaft. Under the felt is a screw. Make sure this screw gets put back in place to hold the advance mechanism in place. Then just attach the weights and springs and go for a drive.
Old 05-12-2010, 02:36 PM
gtc gtc is offline
abides.
gtc's Avatar
If you can't find the pieces or they won't go back together, there was a distributor for sale in the classifieds for $150 a few days ago.
Keep it lubed better next time.
Graham
1984 Carrera Targa
Old 05-12-2010, 02:57 PM
I bought it this way, so I can blame the PO. I used a magnet and found the other spring. This one does not have a screw, it has a small washer and it looks like a split ring, but there is not a grove for the split ring to grab, so it is friction only? Where do you lube these? Remember I am a 911 newb.
Old 05-12-2010, 03:03 PM
AutoBahned
RWebb's Avatar
search for a thread by 911_S_Man (try variants of that) + distr...
you are lucky!
if you were unlucky it would have blown itself apart on a back road - the motor would be ruined & you would die of thirst/starvation/exposure before anyone else drove on the road...
Old 05-12-2010, 04:05 PM
I guess I am lucky. I cannot find anything by that or any other ID close to it, but I will get it back together and see if it works. The little split ring is not easy to get on. I have tried many methods and nothing seems to work, I will continue to work though.
Old 05-12-2010, 07:16 PM
rluciano's Avatar
I think Randy meant "Early S Man" and distr...
Original owner 1986 944
1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds
2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock
72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs
Old 05-12-2010, 07:34 PM
AutoBahned
RWebb's Avatar
closer... Warren posted as Early_S_Man with the underscores included - use that
Old 05-12-2010, 08:28 PM
