Backdating heat with SSI's on a Carrera??
I am looking to hook up the heat after my SSI install on the 87 Carrera. From the earlier Backdating Heat threads the pictures look like the engine tin is changed with the 930 part for heat ducting.
On the carrera the original hole to pass the hose through is in the tin on the backside of the motor..... and everyones pictures looks like the new hose routing is setup to pass through the drivers side tin.
**** Big ?..... Does anyone have a picture of passengers side heat backdate with the original A/C?? .... I cant see how you can fit the ducting under the a/c housing with the backdate setup.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 11-25-2005, 06:51 PM
Senior Member
Do a search. There are several threads with this mentioned.
You have to either change out the sheetmetal to the old style or make a duct that used the old hole on the left side by the dizzy then use two pieces of ducting. I used aviation hose on part and metal on the other, to resist the heat from the muffler.
Its doable but you need to be a bit crafty.
JoeA
Old 11-25-2005, 09:40 PM
In all of my searches I cant find a backdated carrera with oem a/c.
Anyone have it?
It needs to go from the alternator, under the a/c, through the pass side tin and straight down to the SSI.
Old 11-26-2005, 04:29 AM
Senior Member
Use the words "backdate heat" without the word Carrera and you will get 158 hits. Not sure how many or if any have A/C.
Some of the better threads are below:
Why you should backdate your heat on a 3.2
Gratuitous pics of Carrera heater backdate...
Heat Backdate tube length / options
Backdating Heat, Footwell Blowers and Fresh Air Fan
Heating blower re-routed, needed?
Old 11-26-2005, 04:51 AM
Guys what is SSI...sorry newbie question. I've seen reference to backdating and SSI and was curious.
86' 911 Carerra
Old 11-27-2005, 07:33 AM
Registered Cruiser
jorian's Avatar
SSI = Stainless Steel Heat Exchangers
From our Host:
"The SSI heat exhangers are based on the 1974 and earlier 911 exhaust design that was highly optimized for the Porsche 911 engine. 1975 brought about changes in the exhaust that severely limited the flow capacities of the engine, in order to make the engines pass stricter smog standards. The SSI 1974-style heat exchangers are a bolt-on replacement for all thermal reactor cars (1975-77). Using the SSI heat exchangers will make these engines run cooler, make 16 more horsepower (10%), and 28 ft-lb more torque at 3,000 RPM (26% improvement). In addition, the reduced heat from the SSIs will help the engines last much longer. 911SC engines can expect to see an addition of 30 ft-lb of additional torque at 3,000 RPM (increase of 24%). "
Also, SSI's can be fitted to 84-89 Carrera (i have them) but you lose the stock cabin heat setup. So you have to retro fit to the earlier setup, hence the term "backdate."
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 11-27-2005, 07:47 AM
MRM MRM is offline
From our Host:
Jorian, I have been a member here since I bought my car in May of 2000. I have to say your quote from our host and added explanation are the clearest and most concise explanation of the SSI/backdate I have ever seen. After five years and reading a million SSI posts, I too now understand the concept of backdating SSIs. For some reason SSIs and backdating seem to be discussed separately. I always understood what SSIs did, I thought "backdating" them was some sort of a performance option. Thanks.
MRM 1994 Carrera
Old 11-27-2005, 08:01 AM
Registered Cruiser
jorian's Avatar
MRM,
Your welcome. Glad I was able to help.
Old 11-27-2005, 05:09 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Jorian - thanks again, I'm new and have never been able to accurately separate the words properly.
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-27-2005, 06:07 PM
Friend of Warren
The OEM AC will fit, just a tight squeeze on the heater hose. Here are a couple of pics without the AC:
Kurt V
Old 11-27-2005, 06:11 PM
