My 83 SC conked out the other day. I found the coil was s/c primary (0.9 ohms) I have ordered a replacement but this is a long time coming. In the interim I have put in a Bosch GT40 oil filled coil that I had in the shed. The car goes well but I am a bit worried about going too far from home in case it goes again. My question- is there anything special about the original coil. As the car has a CDI I thought that it may need a special coil to handle higher voltages. The GT40 does not seem to get hot.
'83 911SC |
Use an MSD Hi-Vibration Blaster coil. I went through 3 Bosch coils (made in Brazil) in under a year. All leaked out the top. No problems with the MSD and a stock CDI box.
Kirk
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic. - '87 930 - Guards Red - Sold - '82 911SC - Grand Prix White - Gone - '78 928 - Silver - Long gone - '04 Subaru WRX wagon - Sold |
Anyone else had long term success with the MSD Hi-vibration coil?
Kurt |
D idn't E arn I t
Bosch Blue Coil
Bosch Blue coil works perfect with CDI as well. Another choice.
rjp
In the movies only bad guys sleep in king size beds. |
JOT MON ABBR OTH
Just one more item, what type of CDI do you have?
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
'83 911SC |
I also went thru (2) of the silver with brown top coils in 1 year. I switched to MSD cdi and Hi -Vibration coil.. no problems. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
I have wondered the following: if you move the location of the coil so it is in the upright position does that change the type of coil you can use? It seems to me that the upside down position of the coil limits the type of replacement coils that are available?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
JOT MON ABBR OTH
Stock = Bosche
Sorry to be a-retentive here. The PermaTune is silver also but is not stock. When a PermaTune goes bad it tends to send the coil over the edge also. They can be returned to PermaTune for a "free" checkup, but that usually turns up no issues. Replacement is the generally suggested option.
'83 911SC |
regards, greg.
'83 911SC |
'83 911SC |
Greg your answer makes sense but when I said move the location of the coil I meant maybe closer to the fuse box in the engine compartment therefore not in the path of rainwater? I have seen pics of 911 engine compartments where the coil was over on the drivers side in the upright position just wondering if under those conditions does that open the window of additional coils that could be used? For me it doesn't matter because I hope to convert to EDIS ignition in the future.
