mzpps93940
Guest
Posts: n/a
915 Trans Swap
I have '72 911T with a 915 trans that has a noisy bearing on the 5th gear shaft. This is my daily driver and can't afford much down time with it so I was wondering if anyone knew what issues I may run into if I took a known-good 915 from an '84 car and put it in the '72?
Thanks, Marc
Old 10-08-2005, 07:22 PM
Stophos's Avatar
Marc, I believe the that you will loose your speedo until you find a way to convert trans for the mechanical type. Also the gearing is different. I think 72 has 7:31 and the 84 has 8:31 so you will have no low end power. There may be other issues that I am not aware of. I'm sure someone will chime in that has more knowledge on this than I do.
Looking for:
1969 911T - Engine - 6196603 & Gearbox - 7196742
1969 911S - 901/13 Gearbox - 7195559
Old 10-08-2005, 07:40 PM
