-   -   Sway bar experiment = suspension epiphany (http://forums.pelicanparts.com/porsche-911-technical-forum/236912-sway-bar-experiment-suspension-epiphany.html)
Chuck Moreland 08-22-2005 11:43 AM
Thom no doubt you would benefit from larger rear torsions (33mm). Right now you're asking the sways to compensate for a basic imbalance.
Craig 930 RS 08-22-2005 11:49 AM
Yup. The torsions, with the sways you now have, will result in an amazing car.
I cannot beleive how much better the 930 is than the old 3.6.
Perfectly set up. Yours is/will be almost identical to my car.
Have fun -
Randy Blaylock 08-22-2005 12:04 PM
TRG sway bars have three different bars for front and rear that can be used, "A", "B", and "C". The external dimensions are identical, and can be interchanged in the bushings, the lever arms, etc...They are tubular construction, with different wall thicknesses, that correlate to a solid bar of a given size that I don't have the specific numbers right now. The "A" bars are the softest, "B" mid and "C" stiffest.
widebody911 08-22-2005 06:22 PM
In retrospect, I think the sway bar came loose on the "lap from hell." On the next lap, the ass-end of the car was completely unmanagable, and I came in off the track. It just wasn't the same after that. I also bent my LF fender, probably bottomed out with the wheel turned. I drove it today and it felt great. Next to order some 33mm rear torsion bars...
Tyson Schmidt 08-23-2005 12:23 PM
Thom, you are basically compensating for improper spring-rate ratio F/R with the swaybars. What you did is a band-aid fix, but band-aid fixes do work.
You want to set the proper ratio and handling balance with the springs/torsions first, then use swaybars to dial things in after that.
But at least now you can see how much is on the table once you get things straightened out.
widebody911 08-23-2005 02:15 PM
So 33mm or 34mm?
Then we move on to shock valving...
Tyson Schmidt 08-23-2005 02:27 PM
Originally posted by widebody911
So 33mm or 34mm?
Well, 34 would be better spring-rate wise. But I wouldn't risk it with the issues they have in regard to stress-risers near the splines.
So 33mm. But you really should go to coil-overs in back with 450# or 500# springs to balance out the 23mm up front, taking into account the weight distribution of your car, and the aero.
Another option would be to drop the front to 22mm, and run the 33mm in back.
island911 08-23-2005 02:32 PM
. . .or just weld it all in place and start tweaking the tire pressures. (TIC)
Serious Q; what vehicle has the fastest lap time on that track? . . a car or a shifter kart?
widebody911 08-23-2005 02:32 PM
Hmm. Maybe if I sell a bunch of cab tops I can go to coilovers. In the meantime I'll bump up to 33mm rear t-bars and get the shocks re-valved.
I wonder if I should switch the sways back at that point...
widebody911 08-23-2005 02:39 PM
http://www.thunderhill.com/timingrecords.pdf
Looks like 1:43 in a Stohr
Yeah, I didn't know what it was either: http://www.stohr.com/
http://www.stohr.com/images/StohrWeb3.1_08.jpg
bornrich 08-23-2005 02:44 PM
Nope looks like a Formula Atlantic Swift at 1:39 acording to your link.
widebody911 08-23-2005 02:47 PM
Guess I didn't look close enough...
Craig 930 RS 08-23-2005 02:52 PM
How about 33mm with 150 lb helpers on RSR shocks in the rear?
MOre affordable than it sounds, and a GREAT combo.
Jeff Alton 08-23-2005 03:03 PM
Or keep your current T-bars and add the coilovers with a slightly higher rate. The nice thing about the coils is they are cheap if you need to change the rate... Adding the coils will also adress your shock valving at the same time.
Jeff
island911 08-23-2005 03:07 PM
Thanks.
fwiw, it says those are SCCA times only.
A quick google gives http://www.nckroadracing.com/thunderhill_fast_laps.html
in the .125 to .150 liter (heh-heh) catagory they're doing 1:55's
unlimited (whatever that is) they're doing 1:48's
point being, most all their suspension is in the tire. . . . and it's not the massive power getting them around the track so quicky.
widebody911 08-23-2005 03:08 PM
How does adding the coilovers address the shock valving?
Jeff Alton 08-23-2005 04:10 PM
When you add the RSR shocks to mount the springs on, have them valved to match your setup.
Jeff
Craig 930 RS 08-23-2005 04:21 PM
Yep, Steve Weiner at Rennsportsystems in Oregon
dd74 08-23-2005 04:32 PM
Thread spoiler... :D
widebody911 08-23-2005 04:50 PM
Ah; I thought there was some implied Magick inherent in coilovers themselves, which I wasn't gettin'
