-   -   Torque method questions (http://forums.pelicanparts.com/porsche-911-technical-forum/237266-torque-method-questions.html)
Gunter 08-22-2005 11:18 AM
In industrial applications, I rarely came across a situation where dry-torque was required (Like for Titanium)
Accepted procedure was to have a lubricant not only on the threads, but also on the bearing/sliding surfaces like on the flat-washers and underneath the nut.
Of course, on rod bolts, the lubricant is the thread locker.
Wayne, in his Engine-Rebuild-Book, uses what he calls "Nonstatic Torque" meaning steady turning until the torque wrench clicks.
I also remember "Torque value plus an additional segmented turn", like: Torque plus 1/4 turn.
This method of setting the torque, and then tightening an additional amount, was applied under high heat to large-size bolts on turbines.
Where, on a 911-engine, is the "Torque plus ?turn" to be found?
:confused:
