-   -   911 cv joint rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/237317-911-cv-joint-rebuild.html)
pjh69911 08-22-2005 03:56 PM
Maybe someone has had this happen to them too? I reassembled my cv joint (the ball races showed a bit of polish but no pitting)and once all the balls are in, the cage can move, although stiffly, and the center hub is locked. I tried another joint with a similar result. I even tried switching greases. Arghh!!!
island911 08-22-2005 04:04 PM
sounds like you put them together wrong.
Originally posted by john walker's workshop
the inner race and the cage need to rotate in the same direction to disassemble and reassemble. when reassembled, the narrow spacing between the balls on one race faces the wide spacing on the other race. if you get them wide to wide, they won't swivel, then to disassemble from this position, just the cage is turned.
http://forums.pelicanparts.com/porsche-911-technical-forum/86322-cv-joint-assembly.html
http://forums.pelicanparts.com/porsche-911-technical-forum/62514-cv-joint-disassembly.html
yelcab1 08-22-2005 04:31 PM
Happens to the best of us, pull them out and do it again.
pjh69911 08-23-2005 05:11 PM
Thanks for the tips and links.!! I followed the VW service information and now the joints work great. Evidently I was able to put them together with the inner race improperly indexed and this resulted in a hard lock. This board is great. Paul
