GFCC
Jeff's Avatar
Cool And we thought we had Go-Carts... Check out LeeH's 550 replica!
LeeH stopped by yeaterday with his new (to him) 550 replica. Man that is fun to drive! I think I got more waves and thumbs up driving around my Neighborhood in that thing than I've recieved in the entire time I've owned the 911! It's like a Go-cart and at 1400 lbs it scoots along suprisingly fast. Good looking car, here are some pics...
LeeH with his new toy.
And Lee taking my wife out for a ride...
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 08-29-2005, 07:02 AM
Last picture makes your 911 look like as large as a suburban. Well maybe not that big. Very cool car.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 08-29-2005, 07:24 AM
s_wilwerding's Avatar
Is the engine behind the transmission? That's the first 550 Replica I've seen that has that much space between the engine and bulkhead behind the seats.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 08-29-2005, 07:28 AM
Unregistered
sammyg2's Avatar
I was just thinkimg the same thing, I thought 550s were mid engined.
Old 08-29-2005, 07:30 AM
oneblueyedog's Avatar
That car makes a 914 look huge. Nice work.
78SC coupe, Silver Metallic
Old 08-29-2005, 07:33 AM
}{arlequin's Avatar
i was thinking the same thing... seems like maybe a vw beetle chassis was used which would explain the mid- to rear-engine config change.
dave
1973,5
Old 08-29-2005, 07:36 AM
GFCC
Jeff's Avatar
Tom, It sits low. Does kind of make the 911 look big.
Steve, Yes the engine is behind the trans like a 911.
Jeff
Old 08-29-2005, 07:39 AM
GFCC
Jeff's Avatar
Dave, it is on a VW pan.
Jeff
Student of the obvious
LeeH's Avatar
OK Jeff... Didn't know you got a shot of me standing on my head fixing the tach. Where's the one of you with the big grin???
I could hear jeff giggling over the straight pipe as he came back from taking it around the block. It's hard to not like this car.
And in true Pelican fashion Jeff says, "We gotta fix that steering." And proceeded to jack it up and do just that. It had a bit of play in the steering that I assumed was just an ancient VW steering gear box. It turned out to be the steering shaft was loose where it attached to the box! Yikes! That could have been nasty!
Lee
Old 08-29-2005, 07:51 AM
I think all the Beck 550's are mid-engined.
What make is LeeH's car?
Old 08-29-2005, 08:01 AM
GFCC
Jeff's Avatar
It's true... I was like a kid with a new toy when I drove that thing. It just put the biggest Sheeot eating grin on my face. Here's a pic but BEWARE it isn't pretty.
Jeff
Old 08-29-2005, 08:03 AM
LeeH's Avatar
I'm not sure of the make - may be Perry Design. This was an investment car so it'll be on Ebay in a week or two. Sure makes me want a Beck though.
Lee
Old 08-29-2005, 08:08 AM
There's a 550 replica I see every now and then that has a 3.6L stuffed into it.
Old 08-29-2005, 08:10 AM
coool- its got a pre heat trunk in the back!
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-29-2005, 09:43 AM
FasTommy's Avatar
Send a message via AIM to FasTommy
Sweet ride! So what size motor do you have pushing that thing around? I'm sure it doesn't take much in terms of hp to have plenty of fun, but that aftermarket exaust and dual 40mm Solex, "Kadron", carbs are a nice little addition to any type 1.
Tommy Greiner
'66 912
Old 08-29-2005, 01:08 PM
LeeH's Avatar
The seller said 1772 CC. I never took VW math in school, so I don't know how he arrived at that number. Jeff demonstrated that a little throttle input in a turn would break the rear end loose.
Lee
Old 08-29-2005, 03:18 PM
GFCC
Jeff's Avatar
Giddy up! (pun intended)
Jeff
Old 08-29-2005, 04:26 PM
FasTommy's Avatar
oh kool! A stock 1600cc I'm pretty sure had a 69mm stroke and 85.5mm bore. A popular and affordable upgrade which opens up the case and head to receive a 90.5mm piston. Which equates to a 1776.. might have been what he meant. I had quite a bit of experience with those carbuerators on a similar motor I had in my bug in high school. I did some modifications to the bulky air cleaner mount that sits just above the butterfly on each carb, as well as played around with the venturi size, which these 40mm carbs come with is only 28mm. Eventhough it was all for testosterone-filled high school drag racing, I picked up a consistent two-tenths in the quarter mile with that little more top end power. Anyway have fun! Very jealous. Awesome car!
Tommy Greiner
'66 912
Old 08-30-2005, 02:15 AM
Cornpanzer's Avatar
You may wish to relocate that oil cooler. Rule #1 (or at least close) with a VW motor is never block the cooling fan inlet with an oil cooler. You are preheating the cooliing air that travels over the cylinders and heads with that oil cooler which in turn raises the oil and head temps making the cooler hotter and it becomes a vicious cycle.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 08-30-2005, 06:35 AM
flipper's Avatar
So you are selling it? Is that what I heard? Pm me, I am interested!!
2005 911 carrera
57 BMW r50, 2007 Ducati s2r 1000
2007 Boxster (sold)
77 2.7 911s chocolate w/ducktail (Mr Hankey) (sold)
77 930 black (sold)
Old 08-30-2005, 07:39 AM
